So, today i was dumbfounded when i checked my bios version and somehow i missed one. So i updated to the newest motherboard bios, but now.. my 5800x3d is no longer boosting to 4450mhz in games. It is however in benchmarks like cinebench. However before it also did it just fine in games. Like the oblivion remaster. And i cannot for the life of me figure out why it doesnt do it now.
Previously i simply had it on combo strike 3 (So -30) and set the limits to the motherboard that was enough. But now that didn't work. And it only boosts to 3900-4000mhz.
Things i tried:
I reset the bios. Didn't work.
Reinstalled chipset drivers. Didn't work.
Verified the settings did apply, they do. Although ryzen master doesnt give me the curve optimiser option in that program and it says that it is off even though very clearly its on as it works just fine in cinebench.
Also isnt cooling issue as the cpu is running at 60~ degrees.
And its only drawing 40w.
And so I come to this forum to ask for help. Cause I cannot for the life of me figure out which setting I may have missed.
And to make it easier on you guys so you dont need to read my signature:
5800x3d
Msi b450 gaming pro carbon ac
Newest bios i updated to was the latest so, 7B85v1H4(Beta version).
I hope one of you can help me figure this issue out. Thanks in advance.
PC:
MSI B450 gaming pro carbon ac              (motherboard)      |    (Gpu)             Powercolor RX 9070XT Red Devil
ryzen 7 5800X3D                                          (cpu)                |    (Monitor)        2560x1440 165hz (phillips 27m1c5500v)
Arctic Liquid Freezer II 240 A-RGB           (cpu cooler)         |     (Psu)             seasonic focus plus gold 850w
Cooler Master MasterBox MB511 RGB    (PCcase)              |    (Memory)       Kingston Fury Beast 32GB (16x2) DDR4 @ 3.600MHz
Steel series apex pro                       (keyboard)            |    (mouse)         Razer Basilisk v3 pro
https://linustechtips.com/topic/1610060-im-going-crazy-5800x3d/
Is that the latest bios that you are on?
AMD R9 9900X @ PBO | Thermalright Aqua Elite 360, SYY-157
Asus Strix X670E-F | 32GB Lexar Ares @ 6400 30-36-36-68 1.55v
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 3x SN770 6TB
Asus PA602, 2x 200x38, 1x 140x38 | Seasonic Vertex GX-1000
https://linustechtips.com/topic/1610060-im-going-crazy-5800x3d/#findComment-16713888
sounds like:
current PC:
PC configs I used before:
https://linustechtips.com/topic/1610060-im-going-crazy-5800x3d/#findComment-16713906
Does it reach more? If not could be some temp limit enabled.
current PC:
https://linustechtips.com/topic/1610060-im-going-crazy-5800x3d/#findComment-16713907
You can always rollback if youre on Beta, do that first and report back to us. Report this issue to MSI as well if you havent already.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1610060-im-going-crazy-5800x3d/#findComment-16713930
1 hour ago, podkall said:
sounds like:
Hey,, not once did I claim to know what I was talking about 😉
https://linustechtips.com/topic/1610060-im-going-crazy-5800x3d/#findComment-16713931
I forgot to add that this was in games 😁 my bad. In cinebench it gets upwards to according to hwinfo 112 on total cpu powerusage and 110 ppt.
Yes in cinebench it reaches 76c. So still under the 80c threshold.
I guess I can try to go back a bios version, to see if that fixes it.
PC:
https://linustechtips.com/topic/1610060-im-going-crazy-5800x3d/#findComment-16714002
You still asked 🙃
current PC:
https://linustechtips.com/topic/1610060-im-going-crazy-5800x3d/#findComment-16714043
Rolling back drivers did not fix it. I'm currently on the newest one again as I thought reinstalling it may help but no. Also no help there. And nothing I change in the bios seem to make it have a proper effective clockspeed in game of 4450 that I had before.
PC:
https://linustechtips.com/topic/1610060-im-going-crazy-5800x3d/#findComment-16714092
so after some messing about, i went back a bios. changed some things in the bios, made sure both the amd overclocking tab and the overclocking tab itself displayed the same things, changed  ppt tdc edc to 100 70 100
reinstalled afterburner/riva and well it does display my cpu running at 4450 but adrenaline says no. its running at 3800-4100 and hwinfo also says no. its running at 3800-4100 so what do i believe now. xD
PC:
https://linustechtips.com/topic/1610060-im-going-crazy-5800x3d/#findComment-16714384
What do adrenaline and HWinfo show when running cinebench instead of a game? Because looking at that screenshot, you are maxing out your GPU so there would be no need for the CPU to run any faster.
https://linustechtips.com/topic/1610060-im-going-crazy-5800x3d/#findComment-16714456
That's the thing, they show the effective clock at 4450, when its 100% utilised in cpu benchmarks like cinebench. Same as adrenaline. Which makes it weird to me.
The gpu in that seen is indeed at nearly max. But.. its not nearly always the case. There are plenty of moments when the cpu is closed to 80/90% utilisation and the gpu at 80~ and even then the cpu isnt running at 4450 according to adrenaline and hwinfo but now with rivatuners overlay it says it is.
PC:
https://linustechtips.com/topic/1610060-im-going-crazy-5800x3d/#findComment-16714571
