Budget (including currency): 3-3,5k
Country: Austria(EU)
Games, programs or workloads that it will be used for: Games
Other details: https://pcpartpicker.com/list/BnCsWc
This was my first try to make a good gaming pc and now I'm asking you guys what I could improve. I'd like to have 64 GB ram with a 4 TB Storage. Also the AMD Ryzen 7 9800 x3D is my first go to and also the geforce 5080 zotac solid core. The problem is that the current case may be too small to fit the 5080 and the fans. I'd really like to have a case in such design with brown and black and also some fans. Air flow is really acquired as well. Now I'm asking myself which fans and also CPU cooler would be good(water cooling). Also at the RAM which should I choose? Ty for everything!
https://linustechtips.com/topic/1609785-help-me-with-my-build/
You want DDR5-6000 CL30 seeing how games benefit from low latency RAM. I would look for a case with more room.
PCPartPicker Part List
CPU: AMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor  (€523.90 @ Alza)
CPU Cooler: ARCTIC Liquid Freezer III 360 A-RGB 48.82 CFM Liquid CPU Cooler
Motherboard: Asus TUF GAMING B850-PLUS WIFI ATX AM5 Motherboard  (€245.90 @ Alza)
Memory: *Patriot Venom 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory  (€192.90 @ Alza)
Storage: Western Digital WD_Black SN850X 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€286.90 @ Alza)
Video Card: Zotac GAMING SOLID CORE OC GeForce RTX 5080 16 GB Video Card  (€1206.89 @ Proshop)
Case: *Lian Li LANCOOL 216 RGB ATX Mid Tower Case  (€115.34 @ Proshop)
Power Supply: *NZXT C1000 (2024) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (€162.97 @ Proshop)
Total: €2734.80
Generated by PCPartPicker 2025-04-23 20:07 CEST+0200
https://lian-li.com/product/lancool-216/
https://linustechtips.com/topic/1609785-help-me-with-my-build/#findComment-16711940
Looks great to me
https://linustechtips.com/topic/1609785-help-me-with-my-build/#findComment-16711955
Austria but USA PCPartPicker? The huger variant case with SFX power supply? 6800MHz CL38 RAM? Super pricy motherboard... It's not it sadly.
I've cost optimised the build, selected Austria for PCPP and tried sticking with the RGB you've chosen, subjetively I'd argue ring RGB fans fit the case better. Added 1TB boot drive but still kept the extra 4TB one:
CPU Cooler: Gigabyte AORUS WATERFORCE II 360 64.95 CFM Liquid CPU Cooler  (€128.90 @ Proshop)
Motherboard: Gigabyte B850 GAMING X WIFI6E ATX AM5 Motherboard  (€199.90 @ Alza)
Memory: TEAMGROUP T-Force Vulcan 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€101.98 @ Proshop)
Storage: Western Digital WD_BLACK SN7100 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€71.90 @ Alza)
Video Card: Gigabyte GAMING OC GeForce RTX 5080 16 GB Video Card  (€1335.99 @ Proshop)
Case: Fractal Design North ATX Mid Tower Case  (€159.90 @ Alza)
Power Supply: Gigabyte UD1000GM PG5 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (€118.89 @ Proshop)
Case Fan: Gigabyte AORUS EZ CHAIN FAN 120 60 CFM 120 mm Fan  (€19.90 @ Alza)
Total: €2987.96
Generated by PCPartPicker 2025-04-23 19:58 CEST+0200
Desktop: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec 1000W 80+ Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's
Current build on PCPartPicker
https://linustechtips.com/topic/1609785-help-me-with-my-build/#findComment-16712021
