I am not sure when it started but it seems to have started around the new 2.0.28 L Connect 3 update. I have done everything from restarting the pc, unplugging re plugging in the USB, uninstalling and reinstalling L connect and even going to an older version but nothing works. My pc doesn't even registers the AIO in the device manager anymore.
https://linustechtips.com/topic/1609633-lian-li-galahad-2-lcd-no-longer-working/
Is the AIO still working fine and the pump being detected ?
For the LCD, I would try plugging it into another USB port. You can also try plugging it into a power bank while the computer is shut down, just to see if there is any signs of life from the LCD.
Good luck !
contact lian-li support.. they usually respond in 3 4 days
Good luck !
Its a 6 pin usb connector and i have moved it around to other ports and still nothing. as for the pump, its still working just fine, keeping everything cool, the fines on the radiator still spinning.
Unless the connector is visibly broken, I think your best option is to contact either Lian-li support or the retailer where you bought the AIO.
Good luck !
