I am building my 1st PC preferred to be a white theme with RGB, I need some advice or recommendation.
I selected some option below, not sure if it good enough or there is better options.
I have also attached a pricelist pdf of the parts sold in area.
Budget (including currency): SGD $1200- $1500
Country: Singapore
Games, programs or workloads that it will be used for:
- Window Server HomeLab, Using VMware Workstation to run 3-5 vm
- Bluestack gaming
- AutoCAD
- SketchUp
- I don't play High Graphics games or FPS games
- 2x 1440p Monitors
CASING: Darkflash C275P (White)
CPU: RYZEN 7 7700
MB: GIGABYTE B850M AORUS ELITE WF6E ICE
COOLER FAN: TR Peerless Assassin 120 SE Argb
MEMORY: CORSAIR VENGEANCE RGB DDR5 6000MT/s CL36 AMD EXPO
STORAGE: Adata Legend 900 Pro 7400MB/s Gen4 Nvme M.2 Ssd 2TB
GPU: ?
PSU: ?
Dynacore PL 17th April 2025.pdf
Country: Singapore
- Bluestack gaming
- AutoCAD
- SketchUp
- 2x 1440p Monitors
CPU: RYZEN 7 7700
GPU: ?
PSU: ?
For your ram the speed is good but try to find one with a cl of 30 or 32.
Country: Singapore
- Bluestack gaming
- AutoCAD
- SketchUp
- 2x 1440p Monitors
CPU: RYZEN 7 7700
GPU: ?
PSU: ?
Hard to tell how much remains for the GPU... Given your goals I suppose Nvidia is better, a 4060Ti 16GB is the way to go, even if it's bad value, 5060Ti is even worse...
As for the PSU any 750W+ Gold rated from a good brand (Corsair, BQ, ...) will be ok
The pricelist i saw there is TEAM T-FORCE DELTA RGB DDR5 6000MHz CL30 AMD EXPO
I guess this is a good swap?
Nice thanks,
Overall my selection is good for my usage? RYZEN 7 7700
Nice thanks,
Oh yes, pretty nice build, good value for budget, if at normal price
