Budget (including currency): $7000 CAD Please help me lower this lol
Country: Canada
Games, programs or workloads that it will be used for: Gaming and maybe Streaming
Other details: 1440p 144hz(main monitor) 1080p 60hz (second) ((He has these already))
My Friend wants to build his First PC after being a console gamer on PS4 and 5 For for the last like decade, he wants to play basically everything (AAA games, Indie, EVERYTHING) on max settings and giving up nothing.
He is absolutely set on playing at high refresh rate (144hz). He is a stuck on "future proofing" his build wanting it to last forever, he has decided that they way to do this is buy high-mid range parts and try to outlast everything.
All pricing is CAD and found by him on places like Canada Computers and best buy NOT INCLUDING TAX
CPU - AMMD Ryzen 7 9800X3D = $690
CPU Cooler - ASUS ROG Ryujin III 360 AIO w/ 360mm Rad = $410
GPU - XFX Mercury AMD Radeon RX 9070 XT = $1150
RAM - G.Skill Trident Z5 Neo RGB 64GB (2x32GB) = $325
MOBO - MSI MPG X870E Carbon WIFI Motherboard = $750
PSU - LIAN LI Edge Series EG1000 Black = $265
CASE - NZXT H6 Flow (non RBG) = $150
STORAGE - Samsung 990 EVO 1TB SSD = $140
**EDIT** Samsung 990 PRO 4TB = $500
OS - Windows 11 = $180
Extras:
Fans - LIAN LI Uni Fan SL infinity 120 RGB Case Fan 3 PK = $140x2
Fans - LIAN LI Uni Fan SL infinity 120 RGB Case Fan = $40
Fans -  LIAN LI Uni Fan SL infinity 120 RGB Case Fan 140 = $55x2
Accessories - LIAN LI Strimer Plus V2 12VHPWR 3x 8-Pin Female to 12+4-Pin Male = $85
Build Total: is ~$6000 closer to $7000w/ tax
I need help to convince him that this build is unreasonable and he could have similar performance spending much less on the build, anything helps, PLEASE lol
Thanks!
Edited by Hamdotca
It’s not your money. If you’ve already told him it’s unreasonable, then your job is done. Don’t ruin your friendship.
Although, I would get more than a 1 TB drive and at least the pro model. $700+ on a motherboard but a budget ssd lol
So true, I just don't want to see him spend money on stuff he doesn't really need
The SSD is the one thing that I was like "only 1TB??"
22 minutes ago, Hamdotca said:
1440p 144hz
"future proofing"
Uh....
But yeah.....
You already advised him, if he doesn't accept, let him do what he wants with his money.
Not worth to risk some of your bonds with him over something like this anyway.
Plus... sometimes one needs to feel the pain before they can grow/do better .
If he goes by your advice not wholeheartedly, then feel it lackluster later, in the deepest of his mind he might blame ya.
SSD wise, at worst he can just buy another one later and add that to the system.
Especially if he's the type that prefers to separate the OS and everything else into separate disk / partition.
And like I said, sometimes one needs to feel the pain before they can grow/do better xD
Refresh before you reply
As a friend, the main reason you should convince him is if he would be spending money that's not readily available for him. Also give me a build that's similarly spec at a lower price or better spec at the same price. Like using 9700x, a cheaper board, aio, ram psu and fans to get a better gpu, that will overall allow him to get his target of 144hz 1440p. Also advice him to get a decent monitor, as at that budget, half of having the "best experience" is actually related to the quality of your monitor. By the end of it, it's basically what output what the cpu/gpu does. Also tell him, that when it comes to RGB, at the very least, use same brands, so it won't conflict with each rgb software. Or he needs to actually tinker longer to set them up.
6 minutes ago, Poinkachu said:
If he goes by your advice, then feel it lackluster later, in the deepest of his mind he might blame ya.
This is a great point, It is his choice at the end of the day, I just don't want him to feel the pain of money leaving his wallet lol
Yeah we talked about adding more, definitely not the tinker type, like I said it's his First ever build AND First desktop PC
Country: Canada
Extras:
Thanks!
This is one of the worst builds I've seen in awhile. A complete waste of money.
The problem with the "budget" is it really isn't one, it's just how much all the parts he picked cost so it's tough to make budget calls when he doesn't really have one. Just wants to leave absolutely nothing behind, and I don't want him to spend more than he needs too.
RGB is a great shout, appreciate that!
I'd just let him choose the parts give him suggestions and if he doesn't want them or ask for them for that matter then just build what he has in mind and let him be the person that chose wrong you gave him options on what you think he wants so just build it how he wants and let him figure out himself nothing more.
How is this build $6000?!
I've been planning to switch over back to AMD with the 9800X3D, and CPU + RAM + Mobo = $1400.
Maybe ~$150 for a new CPU waterblock. Where is the extra $4000 coming from?
$750 motherboard is just wild, with ONE NVMe SSD.
Why is it just a 1TB SSD?
I'd go at least 2TB these days...with games can hog up ~100GB each.
Which DDR5 G.Skill memory kit is that?
The 64GB (32GB X2) G.Skill Trident Z5 RGB CL30  kit is $290.
https://ca.pcpartpicker.com/product/3c4Zxr/gskill-trident-z5-rgb-64-gb-2-x-32-gb-ddr5-6000-cl30-memory-f5-6000j3040g32gx2-tz5rw
Arctic Freezer III Pro 360 RGB is $230.
https://ca.pcpartpicker.com/product/Xh9nTW/arctic-liquid-freezer-iii-pro-a-rgb-360-77-cfm-liquid-cpu-cooler-acfre00184a
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
This is my bad, talked to him a bit and he has a second 990 Pro 4Tb I'm gonna edit the post
This is the prices he gave me from his build list I'm not sure
If you stream you do it with an Nvidia card.
https://www.nvidia.com/en-us/geforce/guides/broadcasting-guide/
PCPartPicker Part List
CPU: *AMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor  ($689.00 @ Newegg Canada)
CPU Cooler: *Deepcool LS720 SE 85.85 CFM Liquid CPU Cooler  ($144.99 @ Canada Computers)
Motherboard: *MSI MAG X870E TOMAHAWK WIFI ATX AM5 Motherboard  ($459.99 @ Memory Express)
Memory: *G.Skill Trident Z5 Neo RGB 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory  ($299.99 @ Newegg Canada)
Storage: *Samsung 990 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($264.95 @ Vuugo)
Video Card: *Asus PRIME OC GeForce RTX 5080 16 GB Video Card  ($1739.99 @ Best Buy Canada)
Case: *Lian Li LANCOOL 216 RGB ATX Mid Tower Case  ($149.99 @ Newegg Canada)
Power Supply: *be quiet! Pure Power 12 M 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($193.99 @ PC-Canada)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit  ($155.96 @ shopRBC)
Total: $4098.85
Generated by PCPartPicker 2025-04-19 01:18 EDT-0400
Total: $4098.85
I really appreciate this, you have no idea
That kinda pain will be there regardless, especially with current market 😛
As long the system is working well, and the expense doesn't put him in trouble.. whatever.
Me personally at your current position would just look at the list and see if there's parts that I know don't work well together, like choosing crazy high ram or 4 sticks , or adding some add-on stuffs that will requires high expertise (unless he really wants to put the effort into learning about it) etc.
Just tell him if it's future proofing, lower the motherboard, upgrade the gpu.
If he still dont wanna listen, I'd leave him be.
Although, be warned, judging by what you have said so far about budget, doing so is double-edged
there is a chance that by saying that he will keep the motherboard and upgrade the GPU.
The reason I said all this is partly because I assume your friend knows that you're atleast somewhat knowledgeable about PC building, at the very least, more than him.
If he didn't consult you or refused to listen to you, that means most likely he has his own goal that he wants to achieve, whatever it is.
The best argument against future proofing are probably GPUs
When the Nvidia 20-series came out, it added features that previous generations simply couldn't do, namely RT and DLSS. More recently we got features, whether you like them or not, like DLSS FG and DLSS MFG that are exclusive to 40-series and 50-series respectively. Then you have the new transformer model for DLSS4 that only(?) runs on 50-series. Who knows which, potentially must-have, features future generations might add?
He does listen, he's just a bit stubborn lol. we have a good relationship and he knows I'm just trying to look out for him
Very good point, I appreciate the input!
This is nearly a full white-colour matched build.
Everything is there, include a 4TB WD Black SN850X NVMe SSD.
White Sapphire Pure 9070 XT that doesn't use a 12V-HPWR.
That's ~$3600.
I don't know HOW you could possibly spend another $2400+ on RGB and fans, etc...to make it to $6000.
PCPartPicker Part List: https://ca.pcpartpicker.com/list/s9QnC8
CPU: AMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor  ($689.00 @ Newegg Canada)
CPU Cooler: ARCTIC Liquid Freezer III 360 A-RGB 48.82 CFM Liquid CPU Cooler  ($258.74 @ Amazon Canada)
Motherboard: Gigabyte X870E AORUS PRO ICE ATX AM5 Motherboard  ($475.99 @ Memory Express)
Memory: G.Skill Trident Z5 RGB 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory  ($290.98 @ Newegg Canada)
Storage: Western Digital WD_Black SN850X 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($405.99 @ PC-Canada)
Video Card: Sapphire PURE Radeon RX 9070 XT 16 GB Video Card  ($1049.00 @ Canada Computers)
Case: NZXT H7 Flow (2022) ATX Mid Tower Case  ($99.99 @ Canada Computers)
Power Supply: be quiet! Power Zone 2 1000 W 80+ Platinum Certified Fully Modular ATX Power Supply  ($208.99 @ PC-Canada)
Operating System: Microsoft Windows 11 Home Retail - USB 64-bit  ($173.99 @ PC-Canada)
Total: $3652.67
Generated by PCPartPicker 2025-04-19 01:30 EDT-0400
AMD Ryzen Rig
  • AMD R7-5800X
Other than RGB and since he come from console, you also need to ask him is he willing to do regular cleaning and checking the system, which is at least once a month. If not then tell him go for an air cooler instead of an AIO. As for the motherboard, tell him that getting an "E" variant is just a waste if he's just gaming. A b850 or x670 and at best x870 is more than enough. Also since he is thinking playing mostly AAA tittles at 1440p resolution, technically he does not need a 9800x3d. Specially if his GPU isn't maxed out yet. He also don't need 64gb ram, unless he would be doing some professional work. Lastly, if the current parts he picked is already 6-7k cad with a 9070xt. Just show him this build. It's a build with major brands and can still be trim by replacing the air cooler, psu and fan with a more affordable ones.
And again, ask him to get an OLED monitor. If he has no budget and want the "best" thing! Tell him to get the best monitor he can afford. I can guarantee you that, regardless if you have a 5090 and 9800x3d, an true oled vs an ips monitor is a big difference. Ips is great and more than enough, but with his non existent budget and his target experience, he needs an oled monitor.
CPU: AMD Ryzen 7 9700X 3.8 GHz 8-Core Processor  ($439.00 @ Amazon Canada)
CPU Cooler: Noctua NH-D15 chromax.black 82.52 CFM CPU Cooler  ($139.94 @ Amazon Canada)
Motherboard: MSI B850 GAMING PLUS WIFI ATX AM5 Motherboard  ($269.99 @ Amazon Canada)
Memory: Silicon Power XPOWER Zenith Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($121.99 @ Amazon Canada)
Storage: Silicon Power XS70 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($194.99 @ Amazon Canada)
Video Card: MSI VANGUARD SOC LAUNCH EDITION GeForce RTX 5090 32 GB Video Card  ($3749.99 @ Memory Express)
Case: Phanteks XT PRO ATX Mid Tower Case  ($104.98 @ Newegg Canada)
Power Supply: FSP Group Hydro PTM X PRO,Gen5 1000 W 80+ Platinum Certified Fully Modular ATX Power Supply  ($176.00 @ Amazon Canada)
Case Fan: Phanteks PH-F120T30 101 CFM 120 mm Fans 3-Pack  ($169.99 @ Amazon Canada)
Total: $5366.87
Generated by PCPartPicker 2025-04-19 01:40 EDT-0400
That's ~$3600.
Total: $3652.67
Two things to point out:
1. You want a Nvidia card for streaming due to the codecs.
2. Streaming means taking a serious hit on fps. Go big on the gpu.
@ntl0se if your friend is serious about streaming and doesn't want to take a beating on frame rates then the correct way to do that is have one PC for gaming (such as the one I posted above) and another PC for streaming connected via a capture card.
https://www.elgato.com/us/en/p/game-capture-4k-pro  <--- BestBuy, Amazon, etc .. sell this card.
https://mashable.com/article/nvidia-geforce-rtx-5060-announcement   <--- use a RTX 50XX series card (RTX 5060 8GB) on your streaming PC. MSRP: $300 USD
CPU: *Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($153.95 @ Vuugo)
CPU Cooler: *ID-COOLING FROZN A410 BLACK 78.25 CFM CPU Cooler  ($44.99 @ Amazon Canada)
Motherboard: *MSI PRO B760-P WIFI DDR4 ATX LGA1700 Motherboard  ($199.99 @ Amazon Canada)
Memory: *TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($59.99 @ Canada Computers)
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($141.99 @ Amazon Canada)
Case: *Fractal Design Pop Air ATX Mid Tower Case  ($109.99 @ Amazon Canada)
Power Supply: *MSI MAG A750GL PCIE5 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($139.99 @ Best Buy Canada)
Total: $850.89
Generated by PCPartPicker 2025-04-19 02:05 EDT-0400
https://mashable.com/article/nvidia-geforce-rtx-5060-announcement   <--- use a 50XX series card (RTX 5060 8GB) on your streaming PC. MSRP: $300 USD
Total: $850.89
Probably not too serious, but then again I'm not sure, regardless I appreciate all the advice!
Country: Canada
Extras:
Thanks!
The main parts themselves are expensive but good, where he's really overspending is all the useless bling with the AIO and fans, for C$1000 !
With that money he could get a 5080 instead of the 9070XT , but that won't reduce the bill 😛
Also Windows can be gotten for way less
Don't understand why the H6 case, not sure a 360 AIO can fit, would get something bigger.
This has everything but accessories, for "only" C$4200 (Arctic LF3 is scalped in Canada so had to use something else)
CPU Cooler: Thermalright Frozen Warframe PRO ARGB 70.84 CFM Liquid CPU Cooler  ($188.22 @ Amazon Canada)
Motherboard: Gigabyte X870E AORUS ELITE WIFI7 ATX AM5 Motherboard  ($444.99 @ Memory Express)
Memory: G.Skill Trident Z5 RGB 64 GB (2 x 32 GB) DDR5-6400 CL32 Memory  ($334.98 @ Newegg Canada)
Storage: Samsung 990 Pro 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($419.97 @ Amazon Canada)
Video Card: MSI SHADOW 3X OC GeForce RTX 5080 16 GB Video Card  ($1799.99 @ Memory Express)
Case: Lian Li O11D EVO RGB ATX Mid Tower Case  ($249.98 @ Newegg Canada)
Power Supply: be quiet! Pure Power 12 1000 W 80+ Gold Certified ATX Power Supply  ($169.99 @ Newegg Canada)
Total: $4297.12
Generated by PCPartPicker 2025-04-19 05:42 EDT-0400
