4 hours ago, Rad25 said:
How to solve this? With Kernel 6.8 Oracle VirtualBox works fine but not with 6.14.
First ensure the kernel-headers for 6.14 are installed
sudo apt install linux-headers-$(uname -r)
Then try running the command mention in first picture.
sudo /sbin/vboxconfig
Read the output of that command thoroughly
From Linux Mint forum:
Yes, that is the VBox Version/Kernel mismatch error (rc=1908). All you can do is run an older Kernel until VBox development catches up.
You can try it with an earlier 6.13 Kernel version. If it doesn't work, it is a fair conclusion that VBox 7.1 isn't ready for Kernel 6.13.
