Hey all, my new old monitor has given up the ghost so I'm looking for a new one. I'd like a 1440p 144hz (or higher) display that isn't a VA panel (tried one for the first time today and the black smearing was atrocious). I'll be using the monitor mostly for gaming, I play all sorts but I'd like it to be responsive enough for the FPS games I play.
Let me know if I need to add anything else.
Cheers!
https://linustechtips.com/topic/1609349-monitor-recommendations-~%C2%A3300/
Response time and clear image above all else?
current PC:
PC configs I used before:
5 minutes ago, Tan3l6 said:
AOC Q27G4X is quite affordable 180Hz IPS. But it is mainly a budget option.
https://uk.pcpartpicker.com/product/Z2GhP6/aoc-q27g4x-270-2560-x-1440-180-hz-monitor-q27g4x
Will take this one into consideration for sure, just wondering if I can get something better if I spend a bit more 🙂
Thanks!
10 minutes ago, Tan3l6 said:
AOC Q27G4X is quite affordable 180Hz IPS. But it is a budget option.
KOORUI 27E3QK
current PC:
@Tan3l6 I wonder if these are any good:
Asus TUF Gaming (out of stock on cheaper price)
Thanks!
Is ~450 pounds overpushing the budget? (there's a nice monitor but your PC would have to be pretty good too for this one, or at least should)
current PC:
You are asking me? Honestly I haven't followed the (IPS) monitors for a while, but only by specs it does seem marginally better that the KOORUI.
What's this useful for?
There's no review that really pulls out the sensors, only this fella:
current PC:
