icue fan control entirely dead, leaving my 9 fans spinning at their own whims.. sometimes 1500rpm sometimes over 2200 even tho range is maxed at 1800?
Tried to set it in bios but i'm not sure its sticking, right now i've set all fans to do this:
30c: 30%
40c: 40%
60c: 60%
100c???: 100%
Just set it up easy as that, think i need to tweak the settings a bit more for calmer profile setup as its a bit loud just running on 1200-1500rpm just idle right now.
Any program that would help me with managing these fans or am i fucked without using icue's software with the controller like commander pro from icue and rgb hubs i have?
Useful threads: PSU Tier List | Motherboard Tier List | Graphics Card Cooling Tier List ❤️
Baby: MPG X570 GAMING PLUS | AMD Ryzen 9 5900x /w PBO | Thermalright Peerless Assasin 120 SE ARGB | ASUS TUF Gaming GeForce RTX™ 4090 OC Edition 24GB | Corsair Vengeance RGB PRO 32GB DDR4 (4x8GB) 3600 MHz | Corsair RM1000xKingston FURY Renegade 2TB | WD_BLACK SN750 | Samsung EVO 850 | Kingston A400 |  PNY CS900 | Lian Li O11 Dynamic White | Display(s): Samsung Oddesy G7, ASUS TUF GAMING VG27AQZ 27" & MSI G274F,  MSI G274F 27"
Somehow very loud at only 30-40% use.. HW Smart monitor warned me going below 40% might cause odd effects, no idea.
Might have to turn it down further its getting quite loud X_X
I just wanted my uncontrollable rgb mess to be controlled or actually work XD
30c: 30%
40c: 40%
60c: 60%
100c???: 100%
Icues software will probably work best with your fans.
just keeps crashing on startup, keeps happening every few months down the line even when i tell it to not udpate or do anything x'D
Not sure if it'll magicly work down the line haha
