Budget (including currency):
1600 CAD, can be stretched bit if needed but ideally should stay below.
Country:
Canada
Games, programs or workloads that it will be used for:
TV gaming, 99% steam. Playing mostly indie games, some Baldur's Gate 3, some No Man's Sky, maybe a touch of MS Flight sim but I would be ok with it in low setting.
The large majority of games I would like to play are on PC and I do not have one. My goal is to replace my ps4 with that computer for TV gaming, including some couch coop.
I have selected the Fractal Design Ridge as it's easy to fit in the the top space of a Bestå where my ps4 currently lives but I'm open to case suggestions that would fit and be cheaper/easier to build in.
PCPartPicker List: https://ca.pcpartpicker.com/list/jpXLYd
Quote
CPU: AMD Ryzen 5 8400F 4.2 GHz 6-Core Processor  ($199.99 @ Memory Express)
CPU Cooler: *Thermalright AXP90-X47 42.58 CFM CPU Cooler  ($27.90 @ Amazon Canada)
Motherboard: *ASRock B650I Lightning Wifi Mini ITX AM5 Motherboard  ($270.99 @ PC-Canada)
Memory: *TEAMGROUP Elite 32 GB (2 x 16 GB) DDR5-5600 CL46 Memory  ($100.99 @ Amazon Canada)
Storage: *Patriot P300 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($72.98 @ Amazon Canada)
Video Card: *Gigabyte GAMING OC Radeon RX 7600 XT 16 GB Video Card  ($469.00 @ Canada Computers)
Case: Fractal Design Ridge PCIe 4.0 Mini ITX Tower Case  ($169.99 @ Amazon Canada)
Power Supply: *FSP Group Dagger Pro 650 W 80+ Gold Certified Fully Modular SFX Power Supply  ($172.99 @ PC-Canada)
Case Fan: ARCTIC P14 Slim PWM PST 52 CFM 140 mm Fan  ($18.98 @ Amazon Canada)
Keyboard: Logitech K400 Plus Wireless Mini Keyboard With Touchpad  ($44.99 @ Canada Computers)
Total: $1567.78
Thanks for the advice!
https://linustechtips.com/topic/1609251-advice-for-1st-build-since-15-years/
The 8400F isn't a gaming cpu and your choice of RAM is an obvious bottleneck. You want DDR5-6000 CL30 for these AM5 cpu's.
PCPartPicker Part List
CPU: *AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($268.98 @ Amazon Canada)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  ($49.99 @ Amazon Canada)
Motherboard: *MSI PRO B650-S WIFI ATX AM5 Motherboard  ($189.99 @ Amazon Canada)
Memory: *Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($118.99 @ Amazon Canada)
Storage: *Patriot P400 Lite 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($135.99 @ Amazon Canada)
Case: *Fractal Design Pop Air ATX Mid Tower Case  ($109.99 @ Amazon Canada)
Power Supply: *be quiet! Pure Power 12 M 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($136.99 @ PC-Canada)
Total: $1479.92
Generated by PCPartPicker 2025-04-17 16:05 EDT-0400
https://www.tomshardware.com/software/windows/windows-11-free-or-cheap
Total: $1479.92
Thanks for the CPU and RAM recommendations!
How much of an impact would that have? Following what you recommend while keeping in the Fractal Ridge is almost a full 200$ more as I cannot use the case you recommend nor the cheaper ATX size motherboard and power supply.
Any recommendations for a case that fits in a W550mm x H220mm x D350mm space would be welcome as all I can find so far other than the Ridge are 200+CAD htpc cases that are 10 year old designs.
