8 Pin PCIE Power for Seasonic Focus GX-750
Go to solution Solved by OhioYJ,
CableMod? They are about $15 for a basic cable IIRC (Their premade cables, custom will be more). I think MicroCenter's actually started carrying some of them as well. Could just be the extensions, but might be worth looking up quickly if you have one near you.
I have a Seasonic Focus GX-750 and need to buy another 8 pin PCIE power cable for it (2nd GPU for F@H and BOINC). I didn't see any of them for sale on Seasonic's site.
What can I buy that is compatible and available in the US?
https://linustechtips.com/topic/1609065-8-pin-pcie-power-for-seasonic-focus-gx-750/
Push comes to shove, you can get any Corsair type4 cable and just repin a single pin.
Thank you!
I completely forgot CableMod existed. I ended up buying one from there.
