Will my current PC build achieve 200+ fps in games like Minecraft, and Fortnite?
Go to solution Solved by Hinjima,
9 minutes ago, RandomGuy019210982098 said:
Im new to PC building and I want to build a simple gaming PC while on a bit of a budget. Here are the parts to my PC I'm going to build, the parts already purchased so far are the ones with a $0.00 price: Link
I'd like to if the link to my PC I want will achieve 200+ fps in games like Minecraft, Fortnite and maybe a bit of BeamNG drive on 1080p. I don't mind using mid to high settings on those games as well. I'm not sure if this is a realistic hope or not, I'll take some suggestions for parts as well.
Yes, You should definitely get 200+ FPS in Minecraft and Fortnite at 1080p with this setup.
I saw some videos from these games at 1080p high and they were rocking 550+ FPS.  Obviously with a better CPU but 200+ FPS is a realistic goal.
200+ FPS in BeamNG is not going to happen at 1080p high settings.  Maybe around 60-80 fps on high.
Unfortuantely your parts list is private.
Fix this and we'll see 🙂
Just now, RandomGuy019210982098 said:
Alright good to know then, thanks for taking the time to reply 🙂
No problem at all 🙂
This will be a pretty decent 1080p machine actually!
Happy gaming 👍
If you have any further questions or worries, you know where to write.
Oh, and you dont need extra thermal paste! The ID-COOLING FROZN A620 actually comes with a pretty decent sized tube of paste 🙂
Ok thanks, I was wondering how good of a 1080p ,mine was so thanks for your input.
Also thanks lol, I didn't know it came with thermal paste already but good to know now, I'll remove it from my list then
on low it will
on medium itll get around 180 to 190
on high even lower
for minecraft i cant find anything recent to say/share
If you disagree with anything I've said tell my why with logic not feeling
If you wanna correct smb do so with logic not anecdotes and feelings
Awesome!  Some money saved!
The 12400f is a fantastic budget CPU and plenty strong for modern 1080p gaming.
The 3050 is of course nothing special but again, for 1080p gaming its pretty darn solid!  I think you will actually be quite impressed how well it does.
If you have steam, remember to grab Metro 2033 Redux!  Its free to keep.
@Millios Is actually right about that Fortnite performance.
I was looking at competitive settings at 1080p for 500+ FPS.
But again, you will be getting 180-200 FPS and that was your target so that good 🙂
I will admit mistake there.
Alright thanks I don't think I will regret it, and I don't have steam yet but I'll take a look at it thanks. Also, are you able to check for me how many RGB fans I can connect to my mother board? I'm not to sure what the connectors look like even on a diagram so I could use a little help on that. ``/ Will my Jstincal ARGB splitter cables I have in my list help though for all the 6 fans total if the Mobo doesn't have to ability to connect all six?
I will point out that if you’re willing to go used you can get a better GPU for the same money.
"The original Xbox is better than the Playstation 2. Change my mind"
mic drop noise
applause
Sorry, I totally forgot.  Been quite busy and it just slipped my mind.
Its late here so I will go through it all tomorrow and give you a reply.
I have 5 fans daisy-chained to 1 RGB header on my motherboard.
  • 2 weeks later...
It's fine, thanks for the info!
