Budget (including currency): £2000
Country: United Kingdom
Games, programs or workloads that it will be used for: Gaming on highest settings possible
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): just the computer is needed no accesories
Hey please could you help me spec the best buidl for £2000 no requirments other than that just the best possible performance for this price
Thank you!
https://linustechtips.com/topic/1606493-%C2%A32000-build-help/
Highest settings at what resolution and refresh rate?
1080p, 1440p, 4K?
60Hz, 144Hz, 240Hz?
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD0: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/1606493-%C2%A32000-build-help/#findComment-16689882
This board and both of these cards support PCIe 5.0.
PCPartPicker Part List
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (£409.78 @ Amazon UK)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  (£29.99 @ Amazon UK)
Motherboard: *MSI B850 GAMING PLUS WIFI ATX AM5 Motherboard  (£177.77 @ Ebuyer)
Memory: *Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£85.99 @ Amazon UK)
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£87.99 @ Amazon UK)
Video Card: *Asus PRIME OC Radeon RX 9070 XT 16 GB Video Card  (£719.99 @ Ebuyer)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  (£60.46 @ Scan.co.uk)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£99.99 @ Amazon UK)
Total: £1671.96
Generated by PCPartPicker 2025-03-24 20:13 GMT+0000
Video Card: *Zotac GAMING SOLID CORE OC GeForce RTX 5070 Ti 16 GB Video Card  (£807.98 @ Overclockers.co.uk)
Total: £1759.95
Generated by PCPartPicker 2025-03-25 00:58 GMT+0000
https://www.tomshardware.com/software/windows/windows-11-free-or-cheap
https://linustechtips.com/topic/1606493-%C2%A32000-build-help/#findComment-16689890
current PC:
PCs I used before:
https://linustechtips.com/topic/1606493-%C2%A32000-build-help/#findComment-16689986
Thank you!
Here it is :
CPU: AMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor  (£474.69 @ Amazon UK)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  (£32.98 @ CCL Computers)
Motherboard: Gigabyte B650 AORUS ELITE AX V2 ATX AM5 Motherboard  (£169.00 @ Computer Orbit)
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400 CL32 Memory  (£122.49 @ CCL Computers)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£108.98 @ Amazon UK)
Case: Lian Li LANCOOL 216 RGB ATX Mid Tower Case  (£109.00 @ Computer Orbit)
Power Supply: be quiet! Pure Power 12 M 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£119.95 @ AWD-IT)
Total: £1857.08
Generated by PCPartPicker 2025-03-24 22:43 GMT+0000
https://linustechtips.com/topic/1606493-%C2%A32000-build-help/#findComment-16689991
@Why_Me @PDifolco 9070 XT or 7900 XTX? One is more modern and recent, but the other has significantly more VRAM and varyingly better raster.
current PC:
PCs I used before:
https://linustechtips.com/topic/1606493-%C2%A32000-build-help/#findComment-16690064
Tough call tbh.
Total: £719.99
Generated by PCPartPicker 2025-03-25 00:51 GMT+0000
Video Card: *XFX Speedster MERC 310 Black Edition Radeon RX 7900 XTX 24 GB Video Card  (£794.95 @ AWD-IT)
Total: £794.95
Generated by PCPartPicker 2025-03-25 00:52 GMT+0000
Total: £807.98
Generated by PCPartPicker 2025-03-25 00:54 GMT+0000
https://linustechtips.com/topic/1606493-%C2%A32000-build-help/#findComment-16690078
10 minutes ago, Why_Me said:
Tough call tbh.
Personally wouldn't get Nvidia, but, can't really speak realistically because I'd hypothetically favor AMD over Nvidia.
But I'm someone who doesn't care about RT and prefers native over any form of upscaling, so...
current PC:
PCs I used before:
https://linustechtips.com/topic/1606493-%C2%A32000-build-help/#findComment-16690082
7900XTX is only 10% faster, lacks FSR4 and has worse RT
24GB VRAM is overkill and 16GB is always enough, so at £800 to £700 the XTX is worse value (and requires more power as well)
https://linustechtips.com/topic/1606493-%C2%A32000-build-help/#findComment-16690325
