Budget (including currency): $1000 ish CAD
Country: Canada
Games, programs or workloads that it will be used for: Roblox, Fortnite, Minecraft (java and bedrock),
Other details: this is what I thought looked good, any recomendations would be very helpful (I'm not much of a PC builder, but have some PC building knowledge) I'm willing to go over budget a little bit, would prefer to stay at around $1000 CAD
Monitors:1080p 165hz (x2)
(there is no GPU since I'm just gonna reuse my 4060)
https://ca.pcpartpicker.com/user/YourLocalCanadian/saved/mvwXnQ
Edited by YourLocalCanadian
Forgot to add my current peripherals and forgot to add smth
Landon M
https://linustechtips.com/topic/1606477-wanting-recomendations-for-a-build/
Country: Canada
see if your can find a ram kit with a cl of 30 instead of 36.
Country: Canada
The 8500G actually comes with a stock cooler and you don't need to spend a wopping 100 bucks on an AIO.
The stock cooler will be more than adequate.
If you still want a cooler with some RGB then a Peerless Assassin SE120 RGB is half the price.
https://ca.pcpartpicker.com/list/92XyyW
The particular motherboard in this list ( The one you picked ) Should work out of the box with a Ryzen 8500G and should not require a BIOS update.
I checked the motherboards website.
Country: Canada
Better CPU, cheaper RAM, cheaper cooler, better case, mobo and more storage
PCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($279.00 @ Amazon Canada)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler  ($49.90 @ Amazon Canada)
Motherboard: Asus TUF GAMING B650M-E WIFI Micro ATX AM5 Motherboard  ($189.96 @ shopRBC)
Memory: TEAMGROUP T-Force Vulcan 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($119.50 @ Vuugo)
Storage: TEAMGROUP MP44L 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($144.96 @ Newegg Canada)
Case: Thermaltake View 170 ARGB MicroATX Mini Tower Case  ($94.99 @ Canada Computers)
Power Supply: Corsair RM850e (2025) 850 W Fully Modular ATX Power Supply  ($154.99 @ Newegg Canada)
Case Fan: Thermalright TL-C12C-S X3 66.17 CFM 120 mm Fans 3-Pack  ($20.90 @ Amazon Canada)
Total: $1054.20
Generated by PCPartPicker 2025-03-24 13:39 EDT-0400
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
Nice.
Wait why are we 8000 series?
Also 7500F boxed edition comes aswell, with a cooler:
https://ca.pcpartpicker.com/list/Qn3yyW
Could get 2TB NVME, it's nice to have 2TB.
current PC:
PCs I used before:
CPU: *AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($279.00 @ Amazon Canada)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  ($49.99 @ Amazon Canada)
Motherboard: Gigabyte B650M GAMING PLUS WIFI Micro ATX AM5 Motherboard  ($184.80 @ Vuugo)
Memory: *TEAMGROUP T-Force Vulcan 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($119.50 @ Vuugo)
Storage: Crucial P3 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($83.95 @ Vuugo)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  ($82.79 @ Vuugo)
Power Supply: *MSI MAG A750BN PCIE5 750 W 80+ Bronze Certified ATX Power Supply  ($112.99 @ Amazon Canada)
Total: $913.02
Generated by PCPartPicker 2025-03-24 14:07 EDT-0400
What you've compiled has restrictions such as lower PCIE CPU and is wasting money on a needless AIO and so on. Something like this gives you loads of headroom, great value for money and performance. Also 850W PSU gives you the ability to upgrade to most of the high end GPU's:
CPU Cooler: Thermalright Assassin X Refined SE RGB V2 66.17 CFM CPU Cooler  ($33.97 @ Amazon Canada)
Storage: ADATA XPG GAMMIX S50 Core 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($74.99 @ Canada Computers)
Case: Antec NX200M MicroATX Mid Tower Case  ($55.99 @ PC-Canada)
Power Supply: FSP Group VITA-850GM 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($154.99 @ Canada Computers)
Total: $903.24
Generated by PCPartPicker 2025-03-24 14:11 EDT-0400
Desktop: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec 1000W 80+ Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's
Current build on PCPartPicker
Total: $1054.20
one question, how is the 7600 better than the 8500? i thought that newer was better than the previous gen
Landon M
8500 isn't a succesor to the 7600. The 9600 is the successor next in line. 8500 is an APU spinoff generation.
Oh okay, I updated my PC part picker list and I changed it to a 7500F
Landon M
But 7600 is $5 more. Might as well get that, you'll get free iGPU incase your GPU ever dies.
not always, newer isn't always better. In this case 8000 series are worse than 7000 series if you have GPU.
7600(x)
8500G:
Or 280$ + free shipping on Newegg.
current PC:
PCs I used before:
7600(x)
8500G:
Ohh okay, thanks for the information
Landon M
