Why my sapphire Rx 470 8gb core clock speed is 1000mhz and no boost clock speed
First try resetting default tuning settings.
Try using DDU to do a clean uninstall of the graphics driver, then install the latest driver from AMD's website:
https://www.amd.com/en/support/downloads/drivers.html/graphics/radeon-600-500-400/radeon-rx-400-series/radeon-rx-470.html
If that doesn't fix it then check to see if your GPU has a switch on it and flip it when the PC is off
