Hey everyone,
I’ve been struggling with an issue where OBS freezes when streaming MSFS 2024, and I’m running out of ideas on what’s causing it. I’ve done a lot of testing and tweaking but haven’t found a solution yet. I’m hoping someone here might have insights or suggestions. Below is a detailed breakdown of my PC specs, what I’ve tried so far, and the results I’m getting.
My PC Specs:
  • CPU: Intel i7-10700K
  • GPU: RTX 3090 (Latest drivers installed)
  • RAM: 64GB DDR4
  • Motherboard: Asus ROG Strix Z490-E
  • Monitor: Asus ROG Swift PG279QE (G-Sync, 165Hz)
  • Streaming Software: OBS 31.0.2 (Latest version)
  • Game: Microsoft Flight Simulator 2024
  • OS: Windows 11 (23H2)
Summary of the Problem:
  • OBS freezes randomly while streaming MSFS 2024 (usually within 10-15 minutes).
  • No crash logs from OBS, but Event Viewer shows an AppHangTransient error.
  • Bitrate drops to 0 right before the freeze, and OBS becomes unresponsive (white screen, not clickable).
  • MSFS 2024 runs fine before OBS starts freezing.
  • MSFS 2020 does NOT cause OBS to freeze, but FPS is lower, and CPU bottlenecks are more noticeable.
  • GPU usage spikes in MSFS 2024 compared to MSFS 2020, even when settings are lowered.
OBS Encoding Settings:
  • Encoder: NVENC (New)
  • Bitrate: 6000 Kbps
  • Keyframe Interval: 2
  • Preset: P5: Slow (Good Quality)
  • B-Frames: 2
  • Lookahead: Disabled
  • Psycho Visual Tuning: Enabled
  • GPU: 0
  • Max Quality Mode: Enabled
Tests & Changes I Have Tried So Far
1️⃣ GPU Usage & Encoding Analysis
  • Checked Task Manager while streaming:
    • With HAGS ON: GPU shows 50% usage, CPU at 49%, 3D inactive.
    • With HAGS OFF: GPU shows 61% usage (Graphics_1), CPU at 55%.
  • OBS uses 40-50% of GPU when streaming.
  • Video Encoding utilization is high (~45%) in both MSFS 2020 & 2024.
  • MSFS 2024 runs smooth but eats more GPU.
  • MSFS 2020 runs laggy (24-35 FPS), but OBS doesn’t freeze.
2️⃣ Testing Different Aircraft & FPS Locks
  • A350 (Heavy Aircraft, MSFS 2024 & 2020):
    • MSFS 2024: GPU ~54%, CPU ~52%, feels smooth but OBS freezes after 10 mins.
    • MSFS 2020: GPU ~20%, CPU ~23%, feels laggy, low FPS but OBS stable.
  • C172 (Light Aircraft, MSFS 2020):
    • GPU ~51%, CPU ~30%, FPS locked at 36, much smoother experience, no OBS freeze.
    • GPU drops to 43% after locking FPS to 36.
  • Haven’t tested a light aircraft in MSFS 2024 yet (will do soon).
3️⃣ NVIDIA Control Panel Tweaks
  • Power Management Mode: Prefer Maximum Performance ✅
  • Low Latency Mode: OFF for OBS (left it ON for global/games) ✅
  • G-Sync enabled (for fullscreen & windowed mode) ✅
  • Tried disabling “Optimizations for Windowed Games” → No change.
  • Turned off Variable Refresh Rate → No change.
4️⃣ Checking for Driver/OS Issues
  • No NVENC errors in Event Viewer.
  • No “Display driver nvlddmkm stopped responding” errors.
  • Reinstalled GPU drivers using DDU (tried both latest & older versions).
  • OBS was reinstalled completely, settings reset → No difference.
5️⃣ Alternative Encoding Tests (To Rule Out NVENC Overload)
  • Tested recording instead of streaming (CQP 15-20 instead of CBR 6000 bitrate).
    • OBS did NOT freeze, suggesting NVENC isn’t completely broken.
    • However, streaming still causes freezes.
  • Tried switching NVENC Preset from P5 (Slow) to P4 (Quality).
    • Slight improvement but still freezes after ~10 mins.
  • Did NOT try switching to x264 CPU encoding yet (not ideal for MSFS).
Final Thoughts & What I Need Help With
I’ve done a lot of troubleshooting, but I still can’t stream MSFS 2024 without OBS freezing after 10-15 minutes.
Since OBS is stable in MSFS 2020 (even with low FPS), I’m wondering if:
  • MSFS 2024 is overloading NVENC/GPU more than MSFS 2020, causing a stall?
  • Something in OBS’s NVENC settings is conflicting with MSFS 2024?
  • OBS’s bitrate drop to 0 means network issues, or is it just a GPU/encoding issue?
  • Should I try locking MSFS 2024 to 36 FPS like I did in 2020?
I’d love to hear if anyone else is having a similar issue, or if anyone has ideas I haven’t thought of yet.
Thanks in advance! 🚀
