Budget (including currency): I am an idiot who bought a 5090, so I enjoy being scammed out of money but no I did NOT buy from a scalper, I just got lucky with stock in a real shop
Country: Australia 馃檭
Games, programs or workloads that it will be used for: Gaming 4k120, VR, software development
Hi folks, I'm accumulating parts for a new build. I've got the following:
* ROG Astral 5090 LC (the AIO one, 360mm AIO)
* 9950X3D (currently lost in the postal system of Australia)
* Arctic Liquid Freezer iii 420 a-rgb
* 2x48GB 6000MT/s CL28 Trident Z5
* Crucial T705 2TB SSD + Samsung 990 Pro for games
* LianLi O11 Dynamic Evo XL
* MSI mag x870E carbon wifi
* Seasonic GX-1200
As you can see, I am a man of poor taste and poor wits. Double-AIO, full rgb vomit, overpriced 5090.
My question is about fan configs. What I've got to work with in the case is:
* Top 420
* Side 420
* Bottom 420
* That lil 120 you get near the IO ports
Since I've got 2 AIOs already, that means I still need to buy 3x140mm and 1x120mm
My goals are:
* Slight positive pressure if possible
* Intakes use the top, side or bottom since they're dust-filtered
* Exhaust out the top if possible
* Everything individually addressable as possible ARGB
* RGB on the fans isn't "backwards"
I know not all of these are mutually possible, since I've already got two AIOs both of which want to exhaust. So either one of them I need to reverse the fans (now the RGB is blocked a bit) or if I don't I've got negative pressure (and dust comes in through the 120mm).
Which rads and which fans should go where? Can you get "backwards"/intake RGB where the fan support struts are on the opposite side? Do I need an ARGB controller (why doesn't every argb device support daisy chaining)? Which fans should I buy for the remaining spots? If I make one of the AIOs an intake, which one should it be?
https://linustechtips.com/topic/1606084-what-fan-setup-and-fans-already-have-2x-aio/
* Seasonic GX-1200
* Top 420
* Side 420
* Bottom 420
My goals are:
Ill keep this short and sweet, you can put both AIOs to intake for the best thermal results and get "reverse bladed fans" which are intake away from the support struts
Then have 3x140 on the top and 1x120 exhaust out the back to get rid of that hot air and have positive pressure overall, 3x140 + 3x120 intake (restricted) and 3x140+1x120 exhaust (unrestricted), for close to equal but still probably slightly positive pressure, if its not positive, then you can run the exhaust fans a little slower than intake
System specs:
CPU:聽Ryzen 7 7800X3D [-30 PBO all core]
Storage:聽2TB SN850X, 1TB SN850 w/ heatsink, 500GB P5 Plus (OS Storage)
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3)
PCPartPicker List:聽https://uk.pcpartpicker.com/list/QYLBh3
Thanks for replying 馃槉 You reckon replace the fans that come with the 5090 AIO with new reverse ones? I think I saw in a review that the astral does have fan header pins!
Do you know anything about argb? I can only find "hubs" that make all plugged-in rgb the same, but I thought the whole point of argb is that it's individually-addressable!
No, you can keep the ones on it and run a push/pull setup for better temps and then you have the aesthetics down too aswell as better cooling performance
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
