hi, hope everyone is doing fine , i have a very kinda strange issue , first my amp a stereo amp i got it repaired , its now direct like its like you plug it in power it turns on no switch no control over volume always outputting the max volume no bass control nothing , i used to have intel z270 motherboard and when i use my spk with that motherboard i never had any noise or any issue just some static which comes even the computer is off i guess because the amp is always at 100%, now i am switched to amd with gigabyte b450 now the thing is normally there is more static noise then before , but if i am watching movie or anything its ignore able  , but as soon as i run anygame , it starts giving off weird noise crackling sound or like high pitched noise even if the volume in game is 0, as soon as the game start from the black screen to title screen the noise start and if i use headphone everything is fine , i tried a cheap usb sound card , same issue
https://linustechtips.com/topic/1606082-noise-when-run-anygame/
Unless you're using an 'instrument-grade' amplifier with extremely little noise, you should NOT be setting your amplifier to 100%.
You should be setting the digital volume to 100% (or 80% to leave yourself adjustment room) because the DAC output will have far less noise.
If your amplifier is broken and it's stuck at 100%, then stop using it. Done. That's the answer. Buy a new one.
Douk A5 is an excellent budget choice
https://www.amazon.com/Douk-Audio-A5-Amplifier-Bookshelf/dp/B0DS41KM9B/
https://www.audiosciencereview.com/forum/index.php?threads/douk-a5-budget-stereo-amplifier-review.61410/
there is also the SMSL A50
https://www.amazon.com/S-M-S-L-A50-PRO-2-1-Channel-adjustable/dp/B0D1G7R489/
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
https://linustechtips.com/topic/1606082-noise-when-run-anygame/#findComment-16687738
If it sounds like coil whine... Then it's a grounding issue somewhere, probably in the amp
Open-Back -HiFiman Edition XS - AudioTechnica ATH-R70x Refine - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100m - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset *Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
https://linustechtips.com/topic/1606082-noise-when-run-anygame/#findComment-16687787
So it does the high-pitch noise when loading programs or medium-high cpu use?
Sounds like feedback from the board.  Similar to laptops making a noise even if the mouse is moving, feedback from not isolating interference.
As suggested, make sure you are using a grounded outlet, grounded (longer third-prong) psu cable.  If your pc is not using a grounded cable to the psu, this could be part of the isssue.
Most stereo and receivers don't use grounded plugs, nor do active subwoofers with their own built in amplifier.
Try setting Windows volume output to 50% or 10% and try it again.
Could be 100% is just picking up interference and noise from the mainbaord or components.
If you look up the manual for your audio receiver, there may be a way to get it out of direct mode to control volume, and turn on the display again as well.  Manual lib website is quite useful, so type in your stereo model number, and add user manual.
: JRE #1914 Siddarth Kara
How bad is e-waste?  Listen to that Joe Rogan episode.
"Now you get what you want, but do you want more?
- Bob Marley, Rastaman Vibration album 1976
Windows 11 will just force business to "recycle" "obscolete" hardware.  Microsoft definitely isn't bothered by this at all, and seems to want hardware produced just a few years ago to be considered obsolete.  They have also not shown any interest nor has any other company in a similar financial position, to help increase tech recycling whatsoever.  Windows 12 might be cloud-based and be a monthly or yearly fee.
Software suggestions
Just get f.lux [Link removed due to forum rules] so your screen isn't bright white at night, a golden orange in place of stark 6500K bluish white.
released in 2008 and still being improved.
Dark Reader addon for webpages.  Pick any color you want for both background and text (background and foreground page elements).  Enable the preview mode on desktop for Firefox and Chrome addon, by clicking the dark reader addon settings, Choose dev tools amd click preview mode.
NoScript or EFF's privacy badger addons can block many scripts and websites that would load and track you, possibly halving page load time!
F-droid is a place to install open-source software for android, Antennapod, RethinkDNS, Fennec which is Firefox with about:config, lots of performance and other changes available, mozilla KB has a huge database of what most of the settings do.  Most software in the repository only requires Android 5 and 6!
I recommend firewall apps (blocks apps) and dns filters (redirect all dns requests on android, to your choice of dns, even if overridden).  RethinkDNS is my pick and I set it to use pi-hole, installed inside Ubuntu/Debian, which is inside Virtualbox, until I go to a website, nothing at all connects to any other server.  I also use NextDNS.io to do the same when away from home wi-fi or even cellular!  I can even tether from cellular to any device sharing via wi-fi, and block anything with dns set to NextDNS, regardless if the device allows changing dns.  This style of network filtration is being overridden by software updates on some devices, forcing a backup dns provuder, such as google dns, when built in dns requests are not connecting.  Without a complete firewall setup, dns redirection itself is no longer always effective.
https://linustechtips.com/topic/1606082-noise-when-run-anygame/#findComment-16687844
Video?  Cause that description fits coilwhine to a T!
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
https://linustechtips.com/topic/1606082-noise-when-run-anygame/#findComment-16691946
