[HELP] My ARGB fans and HUB are not detected by any ARGB software
Hello I have an ASUS TUF B660m e D4, and I recently bought ARGB fans ( 7 magma fans ) 4 in a dazy chain conected to the MB and 3 connected to a hub connected to the MB ( 5v 3 pins ) and the problem is none of them is detected by any ARGB software, these are the fans am using https://www.gamingdz.com/store/composants/refroidisseur-cpu/PACK-FAN-MAGMA-1236-MIRRO-WHITE-ARGB everything is connected, other devices like my ram is detected and works just fine.
Try other headers if you can, but I'm assuming your bios and OS are detecting the fans?
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
