Hey everyone! I recently bought the AOC Q27G4XF and I have problems with HDR. If the monitor is set to SDR it looks great, but if I enable HDR, everything SDR will become whiter, including the taskbar, background and anything else that isn't streaming HDR. (to the point where blacks are gray and so on)
I did try the windows HDR calibration tool, but it only improved it minimally. Any advice would be much appriciated.
Thanks for the help in advance!
https://linustechtips.com/topic/1605978-sdr-colors-washed-out-in-hdr-aoc-q27g4xf/
Eek, hopefully other AOC Q27 owners will be able to share their experiences and a possible solution.
Windows HDR can be hit and miss.
I have 3 PCs connected to LG OLED TVs and HDR looks great regardless of whether I'm gaming, watching a movie or even just web surfing on the desktop.
My office PC connected to a Philips Momentum 436m6vbpab is terrible and I've never been able to solve it. Enabling HDR makes everything dull and grey. When  connected to a 4k Blu-ray player or a games console it looks better but definitely not when used as a PCs screen.
Sorry couldn't be of more help.
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 3080ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 2080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Kitchen PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Annex - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 1080ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Office - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 980 - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
I know for me personally, my monitor (gigabyte M27Q rev1) has HDR, im able to enable it and it does do something, but its not great, its a HDR enabled monitor but HDR doesnt actually improve much as its a great monitor, but its not phenomenal. So i just leave it off as its inconsistent between games and some games actually look better with it off. Some monitors are HDR enabled but arent built for it very well, they do it, but not well
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3)
Thanks for the replies! On the Windows HDR demo it does look great, it's just SDR that seems to be screwed up, but if HDR is off, SDR looks great as well. So I would imagine there is a setting somewhere that would fix it. (It's an AMD system btw)
7 hours ago, ACupOfTea said:
AOC Q27G4XF
Unfortunately, both of these aren't really capable of HDR and the reason you're having a bad time. You've been caught up in marketing with is a bit of a mess surrounding HDR. Both display can accept an HDR signal which to manufacturers, is enough for them to be marketed as "HDR capable" while in reality, their entry leve IPS or VA panels and edge-lit backlights with no local dimming prevent them from properly outputting a decent HDR image.
You'll be better off just leaving HDR turned off and tweaking the SDR profile.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2
Ryzen 7 5800x - XFX RX6600 - Asus STRIX B550i - 32GB DDR4-3200CL14 - Corsair SF750 - Lian Li O11 Mini - EK 360 AIO - Asus PG348Q
Yeah thats largely where ive ended up, i just leave it on SDR, its a nicer and more consistent experience
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
