Hi, I need help for my first build
Go to solution Solved by brob,
15 minutes ago, Trifo00 said:
Budget (including currency): 2200 euro
Country: Italy
Games, programs or workloads that it will be used for: games like monster hunter wilds, elden ring and coding
I already have a gpu, a 9070xt gigabyte gaming oc the pearless assassin 140 and the rest of the parts list is:
- ASRock B850 LiveMixer WiFi -> 210 euro
- APNX C1 Midi-Tower -> 128 euro
- G.SKILL DDR5 32GB PC 6000 CL30 TZ5N -> 121 euro
- Ryzen 9 9900x -> EUR 455
- MSI Spatium M482 SSD M.2 1TB -> 94 euro
- Corsair Rm850X 80 Plus Gold -> 130 euro
I would like to know if this build can work with the parts that I already have or if I need to change something.
(First time I build a computer)
The outer fan of the CPU cooler overhangs the memory area making the use of tall memory modules less than optimal. Consider using lower profile memory like G.Skill Flare X5 and Corsair Vengeance.
There are numerous versions of the RM850X. While like the more expensive option consider getting the 2024 model. It is ATX 3.1 compliant unlike earlier models.
Country: Italy
https://linustechtips.com/topic/1605866-hi-i-need-help-for-my-first-build/
Country: Italy
All of the components you have listed will work very well together 🙂
I dont know much about coding, does it require more cores, is that why you went for a 9900x?
I don't see a power supply in this list.
ok I corrected the post
I see it now 🙂
The RM850x is a solid unit. I personally ONLY use Corsair RMx lineup as I stand by their reliability.
It is a bit more expensive than an MSI A850GL for example but the RMx is solid.
Everything you have picked out will work really well together and will play games really well.
If you don't need the extra cores from a 9900x for coding then a 9600x and 9700x will be equal in gaming performance and might save you some money.
I dont have anything to complain about really.
1 minute ago, Hinjima said:
I see it now 🙂
Thank you, i was stressing over this for a month now
No Problem.  Absolutely nothing to stress about here 🙂  This is a damn solid list and everything looks great.
Decent motherboard.
6000Mhz CL30 is the sweet spot for RAM.
Great 9070 XT.
9900x is a beast.
RM850x top tier PSU.
Decent M.2 SSD.
Case is subjective but nothing wrong with it.
The Peerless Assassin will cool the 9900x without any problems.
Again, you can change to the 9600x or 9700x without affecting gaming performance.
Overall, Hinjima approved👍
Country: Italy
The PSU is 2021 version, and is the G.Skill that tall?
The particular set you have in the list are quite tall.
The Flare X5 are significantly shorter in height.
I should have picked up on that, good catch by @brob ♥
The 2021 model RMx is fine for the 9070 XT.  The 2024 updated model has the newer updated power cable for Nvidia GPU's.
If there are not a significant difference in price then get the ATX 3.1, but its not super important.
The RMx 2021 model is not ATX 3.x compliant. Still a good PSU, but dated.
In its normal position the outer fan has about 33 mm clearance. Depending on the memory slots used you may have to raise the fan with taller memory modules. You can find the height of the modules you are contemplating at https://www.gskill.com/faq/1502180912/DRAM-Memory.
If you can spend 70-80€ extra on the CPU, you can find the 9800x3d for 520-530€ on BPM Power. They restock multiple times a day.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD0: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
31 minutes ago, Trifo00 said:
for clarity I took the case because it already had 4 fans inside and they are convenient, they are rgb, but the non rgb version is 50 euro more
Fractal Design Pop Air (3)
Lian Li Lancool 207
Lian Li LANCOOL 216 RGB (3)
Montech AIR 903 MAX (4)
Phanteks XT PRO ULTRA (4)
Phanteks Eclipse G400A (4)
Only 1TB of storage?
Western Digital Black SN770
Is there a specific feature you're looking for in MB?
https://it.pcpartpicker.com/list/RH7bcx
current PC:
PCs I used before:
good cooler
current PC:
PCs I used before:
for me the 9900x is good, i geme but i also need it for coding at work
you can spend less than 20€ for 7800x3D
current PC:
PCs I used before:
Country: Italy
Size up on your SSD.
https://it.pcpartpicker.com/search/?q=Lian+Li+LANCOOL+216
PCPartPicker Part List
CPU: *AMD Ryzen 7 9700X 3.8 GHz 8-Core Processor  (€346.11 @ Amazon Italia)
Motherboard: *MSI PRO B850-P WIFI ATX AM5 Motherboard  (€210.99 @ Amazon Italia)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€100.76 @ Amazon Italia)
Storage: *Lexar NM790 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€129.72 @ Amazon Italia)
Case: *Lian Li LANCOOL 216 RGB ATX Mid Tower Case  (€95.73 @ Amazon Italia)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€143.77 @ Amazon Italia)
Total: €1027.08
Generated by PCPartPicker 2025-03-19 15:34 CET+0100
Total: €1027.08
i have another 1TB SSD M.2 and a 1TB SATA in my laptop, i'll take them. I will replace them with a 500GB SATA SSD, since I won’t use the laptop so much anymore
as mentioned before, I’m not going to take any version of ryzen x3d, I don’t want to go for a pure gaming pc
i was looking for PCI 5.0 for the GPU and wifi, the tuf +wifi is onli 7 euro less than the livemixer
Sorry for the delay i'm still at work
why not? gaming PCs can do creative work, 7800x3D will not explode if you start rendering in Blender for example
You technically don't need PCIe 5.0
4090 runs on 4.0, 5090 was benchmarked using 4.0 too.
Loud sound warning: (the embedded video will most likely default to max volume)
(if you don't want to watch entire second, watch 1 minute then skip to about 10 minutes)
current PC:
PCs I used before:
