Cpu goes sky high after booting
Go to solution Solved by PDifolco,
2 hours ago, Fightboy4115 said:
is there any way to check that other than the boot temps because after that it cools just fine and idles at 36.5 with a few apps open
Could you plug the pump cable in another fan/pump header ? Maybe the header has some contact issues
I bought a new pc and it worked fine for the past 2 weeks. but now im starting to notice that everytime i boot my pc for the first time each day my cpu goes up in temps in like 15 secs it goes to 70 to 90 C and then i shutdown due to safety features.
after i reboot it it goes high but catches itself before shutdown and starts cooling down.
This is my pc setup:
cpu:r7 7800x3d
aio: Deepcool Le720
Mb: gigabyte b650 AX
Ram: ddr5 6000mhz cl30 vengeance corsair
Gpu: rtx 5080 ino3d x3 oc
Psu: Msi mag A850GL pcie5
Case: montech XR ATX
https://linustechtips.com/topic/1605862-cpu-goes-sky-high-after-booting/
With AM5 you dont need to worry about powering it down yourself, itll thermal throttle and wont let itself get above 95C which is safe for it to be at. Its probably the AIOs pump taking a bit to kick in, next tie you start your PC, leave it (it wont overheat dw) and see what happens, if the pump kicks in and it starts to cool down.
What temps are you averaging after boot up the second time?
EDIT: Just checked the txt file, 99C on the CPU is quite high, it shouldnt be getting to that at all, even with the pump not running as the water should act like a very large heatsink, it wont dissipate the heat without the pump running, but it shouldnt get past ~95C
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3)
26 minutes ago, TatamiMatt said:
With AM5 you dont need to worry about it power down itself, itll thermal throttle and wont let itself get above 95C which is safe for it to be at. Its probably the AIOs pump taking a bit to kick in, next tie you start your PC, leave it (it wont overheat dw) and see what happens, if the pump kicks in and it starts to cool down.
It's insanely high, Deepcool LS720 is a 360 AIO, temps at boot shouldn't even reach 60C
Cooler is definitely failing
Just on boot i meant, if say, the pump doesnt boot up immediately, thats why i queried the average temps after a second boot where temps dont go as high
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Even then, a properly mounted cooler would have the thermal mass to keep it in check for the 15s that OP says it takes to hit 90
Given the description, this is either a bad mount job or the CPU is misreporting the temps
Why won't the pump start immediately? It's connected to a fan header and should immediately ramp up
Iirc there was a post a few weeks ago with a similar problem
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
i just checked and today it didnt thermal throtle the first time(didnt go above 88,1C) and after reboot it was at the first gpu-z saw was 56.5C and then up to 67.3C but not higher
Gpu-Z 3-20 first time.txt Gpu-Z 3-20 second time.txt
On 3/19/2025 at 3:15 PM, tkitch said:
with that cpu/AIO Combo?
I'd check to see if the block is mounted properly.  The 7800x3d does run warm, but it's not that high a CPU Draw, so it should stay under 90 on a 360mm.
it seems to be mounted properly i made sure of that.
it doesnt even move in the slightest when i wiggle it
