Need to decide ASAP, kindly Help!
Go to solution Solved by Dedayog,
30 minutes ago, KR Ajmal said:
My brother build a PC with AMD 7800x3d and 7900 XT 20GB but i have a option to return it and pay 480$ more to get AMD 9800x3d and 9070 XT 16 GB.
is it worth it?
fyi: I do bit of both gaming and Editing
No, for almost $500 the first one is a better deal.  Sure, the GPU is better, but not worth the uptick.
The 9800X3D is too near the 7800X3D as well to justify.
Keep the one with the 7 series stuff.
is it worth it?
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 1000 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
OnePlus Ecosystem:
Other Tech:
26 minutes ago, KR Ajmal said:
is it worth it?
The GPU is ~5% faster on average and the CPU is about 20% faster in production stuff where you have a shot at noticing the difference (very rough numbers but good enough). That just isn't worth nearly $500 IMO.
The only part of this that has a shot of the difference being worthwhile is the CPU, and you an buy a 9800X3D for the price difference that you can resell the 7800X3D you already own and save money. None of this seems worth it.
