Current 120mm rear exhaust fan recommendations?
Go to solution Solved by SorryBella,
4 hours ago, kingmustard said:
Hoping for some recommendations for a quiet, non-RGB fan, if anyone has any 🙂
The venerable Arctic P12. Unless if you want to bother with researching further specifics in your market (if you want, specify your country), this thing is basically the cheapest non e-waste fans out there for PC.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
