Budget (including currency): 1200-1400€
Country: Germany
Games, programs or workloads that it will be used for: Mainly gaming, but also some programming. I want this build to be able to handle most/all AAA games from the next 7-8 years without any problems
https://de.pcpartpicker.com/list/JnyqrM
CPU: AMD Ryzen 5 7600X3D
GPU: Radeon 7800 XT
RAM: 2*16GB DDR5
Storage: 2TB NVME SSD
750 W PSU
Hello,
im just looking for some feedback on my part list as this is my first selfmade pc and i want to make sure i didn't miss anything important. Here is the reasoning for some of the choices:
From what i could find during research the 7800 XT has the best price/performance ratio of all GPUs within my budget (it fits just barely tho) and since i dont value ray tracing all that much i dont mind not using a nvidia card.
Since i went with a AMD GPU i thought it made sense to also use an AMD CPU and chose the Ryzen 5 7600X3D, because i heard a lot of good things about the X3D CPUs from fellow WoW gamers (the game is very poorly optimized when you play with addons so CPU performance is important here). I also considered the 7800X3D but it was slightly out of budget. I purposefully didnt chose a 5700X3D because i want to keep the option to upgrade my CPU in 5-6 years and thus dont want to be locked into AM4 CPUs.
The rest is just pretty standard stuff from reasonably reputable brands. pcpartpicker estimates the wattage at ~450W,  so i took a PSU that can handle 1.5* that.
I also might wait with purchasing the GPU because AMD is launching their next gen in march and one could hope for prices to drop a bit (they probably wont).
Thanks in advance
https://linustechtips.com/topic/1602144-feedback-for-my-first-non-prebuild-pc/
Country: Germany
GPU: Radeon 7800 XT
RAM: 2*16GB DDR5
750 W PSU
Hello,
Thanks in advance
What is your monitor resolution?
So wow is the main game? x3d chips help a lot with a old game like that that uses very little cores.
Overall not a bad build but can be improved with ease however some more info is needed.
What resolution would you be gaming at and what other games than wow would be played?
the 7600x3d is a waste imo, a 7600 is fine
terrible ram latency, 6000 cl30 is the best
1945 japan for a psu
https://de.pcpartpicker.com/list/6QWmNz
7900 gre goes over so you could stay with the 7800 xt i guess
First custom PC soon(-ish)!
Current part list:
Case: Corsair 4000D (✨WHITE✨)
GPU: Radeon RX 7900 XT
CPU: Ryzen 7 7700
CPU Cooler: Thermalright Peerless Assassin 120 (✨WHITE✨)
Mobo: ASRock B850 Pro RS
RAM: ADATA XPG Lancer Blade 2x16GB 6000MT/s CL30 (✨WHITE✨)
SSD: Lexar NM790 2TB
PSU: BQ Pure Power 12 M 850W
You have 2 different ram kits for a total of 64gb
Theres your issue
Theres your issue
oh i forgot to remove one lol
Current part list:
CPU: Ryzen 7 7700
Current part list:
CPU: Ryzen 7 7700
https://geizhals.de/  <--- compare prices here
https://geizhals.de/microsoft-windows-11-home-64bit-multilingual-pc-a2615378.html
https://www.eurogamer.net/digitalfoundry-2023-amd-ryzen-5-7500f-review
PCPartPicker Part List
CPU: *AMD Ryzen 5 7500F 3.7 GHz 6-Core OEM/Tray Processor  (€153.69 @ Caseking)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  (€39.99 @ Amazon Deutschland)
Motherboard: *Asus TUF GAMING B650-E WIFI ATX AM5 Motherboard  (€151.90 @ Amazon Deutschland)
Memory: *Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€96.90 @ Amazon Deutschland)
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€103.99 @ Amazon Deutschland)
Video Card: *Sapphire PULSE Radeon RX 7800 XT 16 GB Video Card  (€500.14 @ Galaxus)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  (€75.89 @ Caseking)
Power Supply: *Asus Prime AP-750G 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€80.90 @ Amazon Deutschland)
Total: €1203.40
Generated by PCPartPicker 2025-02-18 18:35 CET+0100
CPU: *AMD Ryzen 5 7600X3D 4.1 GHz 6-Core Processor  (€308.90 @ Mindfactory)
Total: €1358.61
Generated by PCPartPicker 2025-02-18 18:55 CET+0100
