Budget (including currency): 2,000 Euros, which is about 10,000 RON in local currency. (This includes the budget for peripherals)
Country: Romania
Games, programs or workloads that it will be used for:
60% of the time = PUBG on steam
20% of the time = other competitive shooters like Warzone, Valorant, maybe Fortnite, idk.
20% of the time = singleplayer titles like Sons of the forest, Palworld, Kingdom Come Deliverence 2, Black Myth Wukong, Elden Ring, whatever i find interesting at that time.
Prices may vary a lot between Romania and USA/Canada, meaning that they are most likely way more expensive here (or maybe some are more expensive, some are cheaper, not sure). I would suggest using/checking https://www.pcgarage.ro/ , it also has the option to create a wishlist with everything that you added in the cart and then share the link to that wishlist, which makes things easier. I will most likely end up ordering everything from this website so that would help a lot in checking for availability and staying in the budget.
I will need a whole setup (including all the peripherals), mostly for playing PUBG, so I would ideally end up with some build that can run PUBG on competitive settings (1080p low) at 200-300fps & a high refresh rate monitor that would make use of all those fps.
Thanks a lot!
https://linustechtips.com/topic/1601894-2025-build-for-mostly-pubg/
My apologies for not using the pcgarage site, I was struggling to navigate it and find certain things. I believe a Ryzen 7 5800x and RTX 4060 Ti would do wonders for your needs, I attached a benchmark video showcasing the performance, towards the end of the video he does a benchmark in 1080p low which is what you described you would use. I put a 27" 1080p 240hz monitor in the pc part picker list as well. I assume since you said you need all peripherals you need a keyboard, mouse, and headset as well so here are my recommendations, although I am unsure if they are available in your country.
Keyboard: Aula F75
Mouse: https://www.mchose.store/collections/mice
Headset: HyperX Could II Wireless
https://pcpartpicker.com/list/rmXyHW
Keyboard: Aula F75
Thanks for taking your time & giving me a reply!
I did add your build to the cart & created a wishlist with it, with the following changes (let me know if any of them are good/bad):
-The motherboard that you've picked (ASUS rog strix one) wasn't in stock so i picked an MSI MPG B550 Gaming Plus for 136$.
-The PSU that you've picked (Thermaltake GF1 one) was like over 150$ here (and it seems to be 90$ on ur website) so i picked GIGABYTE UD750GM, 80+ gold, 750W for 99$
-The SSD that you've picked (Crucial 2TB for 117$) was only available with the 1TB option, so I added that one for 69$
-Couldn't find that specific monitor (and I also wasn't a fan of it being 27" and curved) so i added a LED DELL G2524H 24.5 inch 0.5 ms 280 Hz for 210$
-Couldn't find HyperX Cloud II Wireless so I added Cloud III wireless instead, for 123$
-Couldn't find any mchose mouse on that website so I added a Logitech G Pro X Superlight Wireless 63g for 105$
-Couldn't find the Aula keyboard so I added the Logitech G213 Prodigy for 57$
In the end, this is what the whole setup (pc+peripherals) looks like: https://www.pcgarage.ro/vizualizare-wishlist/5889855 and it costs 7,777 RON (1,639 USD) which means I can still invest (if needed) around 360$. Maybe upgrade the motherboard and ram to DDR5? Maybe go for 64GB of ram? Maybe go for a better GPU? Maybe go for a better CPU? Maybe some other peripherals? Let me know what you think would benefit my use case the most & thanks again for taking ur time! I owe you one.
https://www.techpowerup.com/review/amd-ryzen-5-7600-non-x/19.html
https://www.techpowerup.com/review/asus-radeon-rx-7700-xt-tuf/31.html
PCPartPicker Part List
CPU: *AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (1156.97RON @ PC Garage)
CPU Cooler: *ENDORFY Fortis 5 CPU Cooler  (271.98RON @ PC Garage)
Motherboard: *Gigabyte B650 EAGLE ATX AM5 Motherboard  (781.98RON @ PC Garage)
Memory: *Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (506.58RON @ PC Garage)
Storage: *Western Digital Blue SN580 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (633.78RON @ PC Garage)
Video Card: *Gigabyte GAMING OC Radeon RX 7700 XT 12 GB Video Card  (2226.97RON @ PC Garage)
Case: *Fractal Design Focus 2 ATX Mid Tower Case  (426.98RON @ PC Garage)
Power Supply: *Gigabyte UD750GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (486.98RON @ PC Garage)
Case Fan: *ARCTIC P12 PWM PST 56.3 CFM 120 mm Fan  (42.98RON @ PC Garage)
Total: 6535.20RON
Generated by PCPartPicker 2025-02-17 05:27 EET+0200
Hello,
pubg especially 1080p you need to go amd 3d ,
7800x 3d or 9800x3d,
best ram with the lowest cl (latency
example 9800x3d
air cooler or aio
ram 2x16gb 6000mhz cl26 or cl 28
Any nvme will do
rtx  4060 ti or 4070 super
good psu 850w gold
pubg especially 1080p is more cpu and ram game.
Total: 6535.20RON
This seems like a solid build and the budget is on point, but I was just thinking about the prices of the cpu's and gpu's here in Romania:
Ryzen 5 7600 is 239$
Ryzen 5 7600X is 247$
Ryzen 5 9600X is 279$
i5 14600KF is 256$
i5 14600K is 290$
Ryzen 7 5800X is 196$
Ryzen 7 5700X3D is 283$
Ryzen 7 9700X is 399$
Ryzen 7 7800X3D is 526$
i7 14700KF is 416$
i7 14700K is 448$
i7 14700F is 359$
As for the GPU's:
RX 7700 XT goes for around 483$
RX 7800 XT goes for around 557$
RTX 4060 goes for around 368$
RTX 4060 Ti goes for around 473$
RTX 4070 goes for around 662$
RTX 4070 Ti - not on stock at the moment
What would you pick as the best combo for my use case? (considering the prices here in Romania) for a build that goes around 1,500 - 1,600 USD (2,000 USD is the budget for the whole setup so I would keep 400 - 500 USD for peripherals)
i5 14600KF is 256$
i5 14600K is 290$
i7 14700KF is 416$
i7 14700K is 448$
i7 14700F is 359$
As for the GPU's:
What would you pick as the best combo for my use case? (considering the prices here in Romania) for a build that goes around 1,500 - 1,600 USD (having 400 - 500 USD left for peripherals)
The build I posted comes in at $1375.40 / 6535.20 RON. All the components are from PC Garage.
Yeah, I was just wondering if (considering the prices here), you think the combo of Ryzen 5 7600 + RX 7700 XT would be the best choice in this budget.
The RX 7800 XT for example is like 70$ more expensive than the 7700 XT
the Ryzen 5 9600X is 40$ more expensive than the Ryzen 5 7600
You think these upgrades are worth it? Or should i stick to the ryzen 5 7600 and RX 7700 XT for my use case and budget?
Thanks again!
Thanks again!
That card ^^
