Budget (including currency): $500
Country: USA
Games, programs or workloads that it will be used for: General Gaming, COD, Rivals, fortnight
I wanted to give my nephew an upgrade he currtly is using a prebuilt system only info I have it its using an i7 (up to 3.9GHz 4 core), 16gb , 500gb ssd, no GPU
he has a 165 hz 1080p monitor
Here is what I have on hand I will need to get a case and psu
PCPartPicker Part List: https://pcpartpicker.com/list/jpB8b2
CPU: AMD Ryzen 7 2700 3.2 GHz 8-Core Processor
CPU Cooler: Corsair H60 74.4 CFM Liquid CPU Cooler
Motherboard: Asus PRIME B450M-A Micro ATX AM4 Motherboard
Memory: PNY XLR8 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory
Storage: Samsung 850 Evo 1 TB 2.5" Solid State Drive
Storage: Samsung 990 Pro 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Video Card: EVGA XC GAMING GeForce RTX 2060 12 GB Video Card
I was thining of getting a AMD Ryzen 5 5600X for this and I know he will want some rgp so I will need to find a controller that will work on this board as it dosnt have one.
https://linustechtips.com/topic/1601574-build-for-my-nephew/
3 minutes ago, strange13930 said:
for less than the price of the 2060 you could get a 7600 xt with 16 gb vram
yeah I know but I already have the 2060 pretty much trying to get him somethign that will work petter then what he has and get ride of a few spare parts.
https://linustechtips.com/topic/1601574-build-for-my-nephew/#findComment-16654965
Currently the R5 5600T is cheaper than the 5600 or 5600X.
Get the 5600T over the other two, by far.  (Don't ask me, AMD does stupid naming conventions)
Other than the CPU?  That's a solid starter gaming build.  Maybe replace the H60 with a "new" cooler?  a Thermalright or ID Cooling air cooler will run ~30 bucks, and will do anything that needs.
https://linustechtips.com/topic/1601574-build-for-my-nephew/#findComment-16654968
1 minute ago, strange13930 said:
what case and psu is he using?
I dont know by what by brother in-law has told me its a a dell or something like that prebuilt so I am not banking on the case or psu being usable, Ill have to get both of those but not really concered 850w and probably as ATX with spots for fancy rgb ligting
https://linustechtips.com/topic/1601574-build-for-my-nephew/#findComment-16654977
2700 is a perfectly fine CPU, especially for a kiddo. With the price tag of "free" it can't be beaten. I'm currently buildign a system with a 2700X and in Wukong it got stable 60fps with a powerful enough GPU. Still a good CPU even if statistically 5600 beats it in games.
Whoever priced that Corsair PSU is daylight robbing people. For less you can get a case and a PSU:
CPU: AMD Ryzen 7 2700 3.2 GHz 8-Core Processor  (Purchased For $0.00)
CPU Cooler: Corsair H60 74.4 CFM Liquid CPU Cooler  (Purchased For $0.00)
Motherboard: Asus PRIME B450M-A Micro ATX AM4 Motherboard  (Purchased For $0.00)
Memory: PNY XLR8 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (Purchased For $0.00)
Storage: Samsung 850 Evo 1 TB 2.5" Solid State Drive  (Purchased For $0.00)
Storage: Samsung 990 Pro 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For $0.00)
Video Card: EVGA XC GAMING GeForce RTX 2060 12 GB Video Card  (Purchased For $0.00)
Case: KOLINK Citadel Mesh MicroATX Mini Tower Case  ($56.04 @ Amazon)
Power Supply: Segotep GM 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($87.99 @ Amazon)
Total: $144.03
Generated by PCPartPicker 2025-02-14 10:42 EST-0500
Desktop: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - RMx 750 W 80+ Gold - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's
Current build on PCPartPicker
https://linustechtips.com/topic/1601574-build-for-my-nephew/#findComment-16654978
that is a good point on the cooler that pump has been running for quite a few years.
https://linustechtips.com/topic/1601574-build-for-my-nephew/#findComment-16654987
A 2700 would severely limit the GPU in games like CoD and Fortnite, you're better off getting a 5600 instead. Used like new price on Amazon is $100.
(For a 2700, used on Ebay is the way to go. They go for $20-40)
Ryzen 7 5700X3D (-30 CO all-core) w/ cheap 6-pipe cooler - Gigabyte AX370-Gaming 5 - LPX 2x16GB 3600C18 2R - EVGA RTX 3070 8G XC3 PX1 - Patriot VPN110 1TB -  MSI A750GL - and a dogshit Sharkoon ATX case
Asus ROG G531GT : i7-9750H (-200 Vcore) - GTX 1650M +700mem - Samsung 16+8GB 2666 - 1920x1080@145Hz (172Hz) IPS panel
i5-6400 @4.3GHz (160 bclk) w/ Assassin King 120SE - Z170M-Plus - G.Skill 2x8GB 1R + Micron 16GB 2R @3000C16 - Biostar RX 570 8G w/ MSI Armor cooler
i5-4690K + Z97-AR + Panram Blue DDR3 2800 2x4GB Lightsaber Blue
iMac 21.5" (late 2011) : i5-2400S, HD 6750M 512MB - Samsung 4x4GB PC3-1333 - WT200 512G SSD (High Sierra) - 1920x1080@60 LCD
Acer Z5610 "Theatre" Core 2 Quad Q9550 - 2x2GB PC3-1333 (Samsung) - 1920x1080@60Hz Touch LCD - great internal speakers
https://linustechtips.com/topic/1601574-build-for-my-nephew/#findComment-16654994
that was my experience when using this setup.
https://linustechtips.com/topic/1601574-build-for-my-nephew/#findComment-16655015
Sorry, I didn't properly go through your post. I saw venomtail's suggestion to keep the 2700 and thought you wanted to get one.
But do get a 5600(X) or even a 5700X3d, it'll be worth it for either of those games.
Do you have an idea of what case you want to get?
https://linustechtips.com/topic/1601574-build-for-my-nephew/#findComment-16655448
Not sure will need to be something with a decent amount of rgb hes 12, probably ATX mid size but with enough room to fit a larger GPU in the future
https://linustechtips.com/topic/1601574-build-for-my-nephew/#findComment-16655895
