Yesterday my brothers PC just randomly black screened and become unresponsive. Upon restart the PC would no longer POST and the EZ Debug LED for VGA is on and there is no GPU output.
Specs:
Ryzen 5 2600X
MSI B450 TOMAHAWK
RTX 3070
Corsair RM750X PSU
4x8 GB of Corsair 3200 MT/s DDR4 RAM
I have tried the following:
- GPU in the other x16 slot and different GPU but still the same result.
- removed the CMOS battery to clear settings
- removed RAM sticks in pairs of 2
- measured the PSU with a cheap Chinese PSU tester which reports all rails are good (although it did report a PG of 80 ms - apparently a 'correct' PG would be 100+ ms).
- reflashing the BIOS with Flashback.
- reseating the CPU in case the mount became bad (and immediately after pulling it out and remembering it's a PGA CPU remembered that's very unlikely) which also did not help.
By process of elimination this leads me to believe only the CPU or the motherboard could be at fault. I can try putting the CPU in my rig which has a 5600X to test the CPU but wanted to ask for any other ideas before I disassemble another PC.
Thanks for the suggestions
https://linustechtips.com/topic/1601460-computer-wont-post-stuck-on-vga/
5 minutes ago, strange13930 said:
have you tested the ram?
Yeah sorry, forgot to mention before I first took out 2 sticks, tested and failed, took out the other 2 stick and tested again (this time the RAM light lit up as expected), put back all 4 sticks only to be greeted by the VGA LED
1 minute ago, OddOod said:
Best guess would be a dead motherboard, but can you put the GPU in a different tower and check that it's good?
The second GPU I put in the system to test is my old known to be good 1070. My guess is a dead MB as well, but I'm not sure how exactly it would fail to not boot a GPU on either the CPU or chipset PCIe slots...
Given that you tried a different GPU with no success, i would think that either the motherboard had died or the PCIe controller had died. As @OddOod said above, if you have another PC to test the GPU on check. i fear it may be time to get a new motherboard though
 Main Desktop
CPU: Intel Core i7-14700KF
CPU Cooler: Arctic Liquid Freezer III A-RGB
MB: ASUS ROG STRIX Z790-F Gaming Wifi II
RAM: 32GB(2x16GB) Team T-FORCE Delta RGB 6000MHz DDR5
GPU: ASUS ROG STRIX RTX 4070ti 12GB
STORAGE: 2.048TB Kingston KC3000, 2TB Crucial T500, 250GB Samsung 850 Evo, 1TB Samsung 970 Evo Plus, 240GB WD Green M.2 SATA SSD
CASE: Montech King 95 Pro
PSU: Be Quiet! Straight Power 12 1000W
OS: Windows 10 Home
Monitor: Samsung Oddessy G6 27" 1440p, Viewsonic VX2455 144Hz
Mouse: Logitech G502 Lightspeed Wireless Mouse
Keyboard: ASUS Flare II Animate
Headphones: HyperX Cloud Alpha S Black
Microphone: HyperX Quadcast S
https://au.pcpartpicker.com/user/johnno12/saved/4HDc4D
1
Laptop:
Dell Inspiron 15-5000
CPU: i5-8250U Quadcore with hypertheading
GPU: AMD Radeon 540 4GB Hybrid Graphics
Storage: Micron 1100 SATA 256GB SSD
OS: Windows 10 Home
1
