Possible Bottleneck with RTX 5080?
7 hours ago, Jeancly said:i mean, i usually have gpu at 99% with my rtx 3080
That means you're always GPU limited (i.e. what you generally want) never CPU limited in any game you've tested. Which is what people would typically describe as "no bottleneck", even if your GPU is technically the bottleneck here. That tells you there's room to upgrade to a faster GPU, while a faster CPU wouldn't help.
According to the bottleneck calculator of pc-build.com an RTX 4080 (they don't offer a 5080 yet) would give you a "9.1% bottleneck". What useful info does this number give you?
At best it could mean you'd become CPU limited in some games, but it doesn't tell you which games those are and whether the CPU limit in these games is even significant enough to worry about. As long as the CPU limit isn't so bad that games are an unplayable sutterfest, a CPU upgrade is usually not needed or worthwhile.
