PC won't post
22 hours ago, TwentySixHundred said:Having the same issue with boot loop for the past month now... Don't want to hijack your thread however almost the same setup. Basically the same specs and replaced nearly the whole PC at this point with no luck. Now it's at the point of where it tries to boot twice and just gives up.
Swapping out RAM config and for an Crucial 8GB stick i have laying around makes no change.
Can enter BIOS and flashed to newer and original versions.
Reset CMOS, changed cables ect. Also CPU is about 6 months old and have no hair left after messing with this rig.
Hopefully one of us can find the issue
Replaced:
PSU: MSI 750W Bronze
Motherboard: As below
SSD: Crucial BX550
Specs:
Motherboard: B550M K
CPU: AMD Ryzen 5600G
GPU: null
Ram: 16GB Corsair
So today I got it working by swapping out each device on my PC from one off of my brother's old PC until it would boot properly, started with the CPU (AMD 3600) and worked my way down to the motherboard which ultimately got it working on first boot. It was a B550 UD AC motherboard and it's been working fine so far.
I don't know if you tried swapping out the motherboard yet but that might be what's holding it back from posting correctly, hope this helps.
