Want help for a build! (First PC)
18 minutes ago, R10_JR said:Purely for gaming and want to do some emulation. Also have Microsoft Flight Sim 2020
For emulation you might wanna get an nvidia card then and the 5080 is like 5 to max at best 10% better than it so the price jump isnt really worth it
20 minutes ago, R10_JR said:I would like to have an x870 chipset as it has gen 5 pcie so if I decide in the future to get a gen 5 card I won’t have to upgrade my motherboard. But would like advice if this is a stupid decision cuz I don’t know what to do. Also does it matter because I do want to overclock cpu and GPU if possible?
There are motherboards that have PCIE gen 5 and many in the b850 chipset and it doesnt dumb to want it even though PCIE 4 is also crazy fast but anyways
Also no it wont matter, as long as your PSU and the motherboard (most decent and good b650 and b850 boards) will handle it like a champ
22 minutes ago, R10_JR said:For the PSU it’s a Cooler Master 850w Gold power supply.
For the cooler thanks for the info I will see what a 360aio cost my other option was the Deepcool AK620 Digital ARGB Air CPU Cooler
Smt a bit more like the model would be needed for the PSU but I'd also like a bit of a stronger unit like a thermaltake GF3 or an MSI A850GL or A1000G (MSI ones tend to be cheaper in some places)
For the cooler I'd suggest gettin a Liquid freezer 360 III from arctic or thermalright peerless assasin 120 from thermalright
