Recommendation aio cooler for ryzen 9 7900
Go to solution Solved by Hinjima,
1 minute ago, Little_moon said:
I am willing to build a pc :
Amd ryzen 9 7900
Rtx 4060ti 16gb
GIGABYTE aorus B850 or x870
Basiclly for 3d art works using blender, zbrush, substance painter... etc
I want an aio that would be sufficient and quite as possible for this heavy works and thank you
Arctic Liquid Freezer III lineup are good AIO's without breaking the bank.
A Ryzen 7900 can easily be cooled by a Peerless Assassin SE120 though, its a 65w CPU.
Amd ryzen 9 7900
Rtx 4060ti 16gb
https://linustechtips.com/topic/1600753-recommendation-aio-cooler-for-ryzen-9-7900/
Amd ryzen 9 7900
Rtx 4060ti 16gb
Even with PBO enabled (which kind of makes it an 7900X or higher) the Peerless Assassin still cools it well. Even when i run 2 instances of handbrake at the same time and all 12 cores are at 5.1GHz, it stays under 90°C in my Fractal Torrent Compact.
I wonder if OP wants AIO for looks, or actual (perceived) cooling requirement?
No signature
Sure. A PA-SE120 is plenty but OP mentioned the want for an AIO so I gave my recommendation without overspending on one.
Hence why I also mentioned the PA-SE120.
No, I don't care about the looks.. in fact I will probably turn off all rgb lights. Sorry I should have menshioned that earlier but I live in a pretty hot area where temperatures tend to rise at 40 or 45 in summer. So I was just wondering if there is an aio cooler that can handle the heavy works running by blender at such high tempreatures with no air conditioner in room.
I have done some search and found the arctic liquid freezer iii 360 is actually doing great job with amd rather than intel.
That's what i found in this video...
https://youtu.be/jMeH7SJO74Q?si=4CrLAx_QHt5-aIOM
Those are pretty warm temperatures indeed and an 360mm AIO will be better for high sustained loads.
The Arctic Liquid Freezer III lineup is one we recommend a lot, the performance to price ratio is absolutely fantastic.
I don't personally care for AIO's in terms of Aestethics but the Freezer III does look rather good!.
The 7900 non X is a 65w chip but some cooling overhead doesn't hurt if you can afford it 🙂
This will be an amazing system.
I would check out a Thermalright AIO. I get killer performance.
AMD R9 9900X | Thermalright Aqua Elite 360 V3, 6x TL-B12
Asus Strix X670E-F | 32GB Lexar Ares @ 3000 30-36-36-68
Zotac 4070Ti Trinity OC | WD SN850, SN850X, 3x SN770 6TB
Asus PA602, 2x 200x38, 1x 140x38 | Seasonic Vertex GX-1000
