Beyerdynamic DT 990 Pro 80ohms with the Rode AI-1
Go to solution Solved by Crystallight,
Seem to have "solved it" putting the AI-1 output and input to 24bit 88200 HZ seem to have made audio play without any crazy high pich sounds will keep testing them with music and gaming and see if it was just that simple.
Not 100% sure what im doing wrong but soon I plug the jack into the Rode AI-1 and play a video it doesnt do any sound or it play an crazy high pich sound.
I was hoping is be an simple plug in and work.
Anyway got any clues what im doing wrong or does not work like an simple plug though the Beyerdynamic DT 990 Pro has the right jack and all for it.
I have the AI-1 and similarly driven headphones, no issues here.  All I can say is that there could be some kind of grounding issue with the USB cable?  It's supposed to be pretty straight forward..... Plug in USB, plug in headphones, hear sound.  There is always the off chance of software shenanigans so maybe reinstall the device?  I've had zero issues with mine.
*could be a faulty unit
Open-Back -HiFiman Edition XS - AudioTechnica ATH-R70x Refine - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100m - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset *Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
Well that what is weird I plug into my computer as you can unscrew the bigger jack to use for phones and such.
It works completely fine that way.
Is there an setting I need to change in windows like the hz's or the audio?.
I also note this but I think shouldn't make an differences It came with an usb A to usb c cable in the box but was quite sort so I just used an usb c to usb C cable.
I'm pretty sure it's a faulty unit, Rode has excellent customer support.  I would contact them
DAC S.M.S.L SU-9
Odd, never heard of such a thing.  Glad you figured it out.
DAC S.M.S.L SU-9
there is a audio playback mode on the AI-1 that.. plays back the sound made by the microphone. Due to audio dark magic, if you put your headphones near the microphone you can get a loud, high pitched sound. Feedback. Exactly the same thing when you hold a microphone up to a PA speaker that said microphone is attached to.
Make sure that isn't activated.. you get it by pressing down one of the volume knobs.
