Budget (including currency): 1000€ (I can go over the budget if needed and/or it increases my performance significantly)
Country: Germany
Games, programs or workloads that it will be used for: Unity, Coding (Java, C#, Phython, Css/html), Gaming (e.g. Wuthering Waves, Elden Ring, GBF: Rising)
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc)
https://de.pcpartpicker.com/list/MVZsnp
I am updating from a shitty laptop and plan to buy the parts + a monitor in within the next 2 weeks. As for peripherals I won't need any. As for the resolution I probably play at 1080p 1440p isn't really needed. Not sure about the refresh rate though.
P.S: If you recommend me another GPU then please a GeForce one bc it has some specific features I need and with 16 GB of RAM.
Thanks in advance!
https://linustechtips.com/topic/1600622-opinions-on-first-build/
Heres some changes in the same budget range as your list.
PCPartPicker Part List: https://de.pcpartpicker.com/list/Z2P3gn
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (€205.87 @ Galaxus)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  (€39.90 @ Amazon Deutschland)
Motherboard: ASRock B650M PG Lightning Micro ATX AM5 Motherboard  (€119.08 @ Amazon Deutschland)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€95.90 @ Amazon Deutschland)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€119.90 @ Alza)
Video Card: PowerColor Hellhound OC Radeon RX 7800 XT 16 GB Video Card  (€498.90 @ Mindfactory)
Case: Montech XR ATX Mid Tower Case  (€59.90 @ Alza)
Power Supply: MSI MAG A650GL 650 W 80+ Gold Certified Fully Modular ATX Power Supply  (€87.90 @ Amazon Deutschland)
Total: €1227.35
Generated by PCPartPicker 2025-02-07 22:57 CET+0100
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
https://de.pcpartpicker.com/list/2P4qPJ
- better mobo
- 32gb ram
- cheaper 4060 ti 16gb
First custom PC soon(-ish)!
Current part list:
Case: Corsair 4000D (✨WHITE✨)
GPU: Radeon RX 7900 XT
CPU: Ryzen 7 7700
CPU Cooler: Thermalright Peerless Assassin 120 (✨WHITE✨)
Mobo: ASRock B850 Pro RS
RAM: ADATA XPG Lancer Blade 2x16GB 6000MT/s CL30 (✨WHITE✨)
SSD: Lexar NM790 2TB
PSU: BQ Pure Power 12 M 850W
Country: Germany
Thanks in advance!
Your RAM was awful
I'd also try to get a 9600 and a 4070, you have some less VRAM but the card is way better for like 30EUR more only
CPU: AMD Ryzen 5 9600X 3.9 GHz 6-Core Processor  (€258.82 @ Caseking)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  (€41.89 @ Proshop)
Motherboard: MSI PRO B650M-P Micro ATX AM5 Motherboard  (€123.99 @ Galaxus)
Memory: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€99.90 @ Amazon Deutschland)
Storage: Silicon Power A60 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€116.85 @ Galaxus)
Video Card: Gigabyte WINDFORCE OC GeForce RTX 4070 12 GB Video Card  (€569.00 @ notebooksbilliger.de)
Total: €1358.25
Total: €1227.35
they said they need an nvidia gpu
Current part list:
CPU: Ryzen 7 7700
