Hi, my motherboard has two RAM slot. It's the Asus H510M-E. 64 GB Max Ram allowed.
Currently, it has only one stick of 8 GB DDR 4 2666 Mhz.
I want to buy one stick of either 16 GB or 32 GB but 3200 Mhz.    If I do that, will it conflict as one RAM stick has 2666 Mhz and the other 3200 Mhz?
Either 24 GB or 40 GB will be good for me.
Do both need to be same size and speed or it may cause any issue?
Thanks
It'll be just fine.
Both the sticks will run at the lower speed. For example, if your new stick is 3200Mhz capable, it will still run at 2666Mhz alongside your old one.
Regarding the size, there should be no problem at all. There are many laptops on the market right now with 24GB RAM.
Corsair SF750 | FormD T1 V2.5 Black | Asus B650E-I ROG Strix Gaming Wifi | AMD Ryzen 7 7800X3D | 32GB 6000MHz Team T-Create | Asus RTX 4080 Super ProArt OC | MSI MPG 271QRX QD-OLED
R Λ Z Ξ R Viper V3 Pro | HHKB Professional HYBRID Type-S Charcoal Blank | Artisan Hayate-Otsu Soft | Beyerdynamic DT 990 Pro | JDS Labs Atom Stack | RØDE PodMic | RØDE AI-1
22 minutes ago, nano_705 said:
It'll be just fine.
Thanks. Many were saying to get both of same stick as 16gb x 2 or 8gb x 2 OR I would face issues. I was like why lol
It's not necessarily going to be fine. They might POST at the lower frequency or just not POST at all. There are no guarantees when it comes to ram of different kits, your system might not even POST depending on how out of sync the ram timings could be. The only time a RAM configuration is sure to work is if it is validated by the mobo manufacturer for your cpu.
Current PC:
    • CPU
      AMD Ryzen 9 9950X3D
    • Motherboard
      MSI MEG X870E Godlike
    • RAM
      G.Skill Trident Z5 Neo 24GBx2 DDR5-8000 CL40-48-48-128 1.40v (F5-8000J4048G24GX2-TZ5N)
    • GPU
      Aorus Xtreme Waterforce RTX 3090 TI
    • Case
      Corsair 7000D Airflow
    • Storage
      (All NVME SSDs) 1 X Samsung 990 Pro (4TB), 2 x 2TB WD Black sn850, Sabrent Rocket 4TB
    • PSU
      Corsair AX1600i, Fully Modular, 80+ Titanium
    • Display(s)
      Alienware AW3423DW, Alienware AW3225QF
    • Cooling
      Arctic Liquid Freezer ii 420, Built in 360mm gpu rad, 7 x 140mm Noctua NF-A14's (4 used as full case fan set, 3 used to upgrade cpu rad fans), 4 x 120mm Noctua NF-F12's (3 used to upgrade gpu rad stock fans, 1 used to fill last remaining case fan slot)
    • Keyboard
      Custom Keychron Q6 Pro
    • Mouse
      Asus Rog Spatha X
    • Sound
      SteelSeries Arctis Pro + Game DAC Wired Headset
    • Operating System
      Windows 11 Pro
