Are PSU cables interchangeable from the same model?
Solved by Hinjima,
2 minutes ago, CanadianIron said:My brother has a CORSAIR RMx Shift Series RM1200x Shift for his computer and I have a CORSAIR RMx Shift Series RM850x Shift. I don't like using a daisy chain cable for my graphic card, and was wondering if I can use one of his extra PCIE cables on my power supply? Are all of the cords interchangeable because they're the same model?
Yes. Corsair cable between the RM1200x Shift and RM850x Shift are compatible between each other.
Corsair has their own compatability chart for cables.
https://www.corsair.com/us/en/s/psu-cable-compatibility
https://www.corsair.com/us/en/s/legacy-psu-cable-compatibility
