Small damage to pci lock on gpu
Go to solution Solved by manikyath,
that part of the pcb is nothing but PCB material, there's nothing there to get damaged.
If this is the only damage the card has, then just forget about it. The purpose of that tab is to click in the holding bracket of the motherboard.
Did that damage happen by your hand or was the card like that when you purchased it ? This could be indicative that this card was used before.
Have a nice day !
