1440p gaming build for RTX 4060 (Sweden)
Solved by Millios,
For that budget you are not getting your moneys worth in any way shape or form
https://se.pcpartpicker.com/user/OmegaTheMan/saved/LsBF4D
The extra USB ports I assume will be for instruments but you dont need them
Just get a USB hub as you dont really care about latency there
Mikey89 ·
Posted in Graphics Cards2 -
1
t0we ·
Posted in Power Supplies0 -
Atomic microwave ·
6
1
Actual_Criminal ·
Posted in Phones and Tablets0 -
zetorminator ·
Posted in Displays8 -
5
