PC Froze then it couldnt boot - EZ debug lights cycle between CPU and DRAM
Solved by Lemtea,
2nd dimm is dead. it is not uncommon for ram to die suddenly (at least its more obvious than intermittent stability issues). Your options are to continue with the single stick, try to find a ram stick with the closest spec/revision to replace the dead one (no guarantee that you will be able to run the rated speed and its possible the other stick may not last much longer) or replace the memory with a new kit. Given the pricing of ddr4 I would be inclined to suggest just replacing the entire memory kit as it would be the only way to ensure you have a memory kit validated for the rated speed.
