Help with 5080 buy
2 hours ago, Pdizzy said:Budget (including currency): no budget (i want to buy what i need)
Country: US
Games, programs or workloads that it will be used for: marvel rivals, single player high graphic games, val, etc.
1440p 480hz monitor (what i want to play on)
Current setup:
5800x3d
corsair h100i cooler
msi b450 tomahawk
corsair 32gb memory
980 pro 1 tb, 2tb ssd
evga rtx 2070 xc ultra
Corsair RM1000x (2021) 1000 W 80+ Gold
I have a question if my psu is okay for the 5080 because I know that using the split connector is not good, i just got this psu like a year and half ago. Do yall think it will be okay? Also my mother board is not 4th gen pcie, is it worth upgrading even if i want to keep the 5800x3d bc its a good cpu still? Will the performance boost be alot with 4th gen, also if it is then I would also upgrade for more m.2 slots. The only thing is, i was thinking of just saving for later to upgrade my cpu and motherboard and ram to am5, and i dont want to just waste money if i dont have to.
The PSU should be fine. There is nothing wrong using an adapter for the GPU power. Just make sure all connections are well seated.
Using a PCIe 3.0 slot for the RTX 5080 is likely going to sacrifice some performance. But the uplift from an RTX 2070 will be remarkable. I would not change the motherboard unless moving to AM5 with PCIe 5.0. Which essentially means a new system.
