I'm currently thinking about getting a new monitor for my gaming setup this year instead of an upgrade (new 50 series graphics cards bench marks haven't impressed me enough to upgrade)
I'm most likely looking for 4k resolution and around 140-165hz refresh as I don't play competitive at a high level and I'm currently running a 3090 so wont be able to hit higher than that in most games anyway but will more than likely upgrade next generation.
I'm currently using the original Samsung g9 and due to my use case which is mainly games however when working from home I leave my gaming pc on to play things on Youtube in the background I want to avoid something that would easily get burn in (which I believe I have on my g9 as the mark follows my old desktop background with a blue line that shows on light backgrounds).
Its been nice having a 49inch screen however a lot of games i've play have had issues or just dont support it so i'm looking to down size and i'm currently thinking of moving to 32inch as i'm most likely also going to down size my desk.
I would be grateful if anyone could advise on a 4k monitor 32 inch at that refresh for my use case  (if there is an amazing 27inch I could be persuaded). Budget wise I would be looking at something up to £800.
Bonus if there is a similar looking model in range that is 1080p and cheap I could use along side it for a second screen for videos/web suffering while playing games that kinda matches.
https://linustechtips.com/topic/1598147-new-monitor-advice-help/
