looking for a cpu upgrade., help
Go to solution Solved by --SID--,
12600K should be found under $/€200 new. Motherboard for 100 - 150 and you're ready to go.
Budget (including currency):
350 USD
Country:
Israel
Games, programs, or workloads that it will be used for:
Gaming, editing work and browsing ig.
Current setup:
CPU: Intel Core i7-9700K
GPU: NVIDIA GeForce RTX 3070 Ti
Motherboard: Gigabyte Z390 Gaming X-CF
Resolution and refresh rate: 1080p @ 240Hz
16 gb of ram
Looking for a CPU upgrade
Willing to consider a motherboard change if necessary for the CPU upgrade.
i generally thought about the intel i9 12900k but not sure
https://linustechtips.com/topic/1598092-looking-for-a-cpu-upgrade-help/
350 USD
Country:
Israel
Current setup:
16 gb of ram
How much is a 9900k for you?  Hyper threading adds a nice uplift.
Otherwise a mobo + 12900k would be a good fit if price is right.
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Sage Ryzen 7800X3D - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 CL6000CL32 32GB - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
OnePlus Ecosystem:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
i looked a bit and saw that the 9900k is overpriced because of market high interest. at 400 dollars and saw that i can get a 12900k and a z790 for 460 dollars should i consider it or is there a better option?
Ryzen 5600 would be an upgrade, without having to buy DDR5 RAM and is probably the cheapest option.    Or even a Ryzen 5700X3D + mobo is peak gaming before you get to DDR5,  UNless you can find a 13600K + DDR4 mobo in your area.
OnePlus Ecosystem:
Other Tech:
