Ok Fan Curve ?
Go to solution Solved by podkall,
Sure works, if it's for noise you can always adjust, if it's just for temps there's nothing wrong with it, the fans will go 80-100% after 81C average,
55-79% fan speed between 70-80C,
if the hotspot delta is 20C or less, it's perfect temperature wise.
Auto all the way really, personally. And yes thatll work, just remember to add Hysteresis of 5-10 degrees.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1598014-ok-fan-curve/#findComment-16634991
Auto on my card tries to keep it under 60c during any load so during heavy gaming the fans ramp up very high for no reason.
I had to make a custom fan curve to allow a bit higher temperature to reduce noise.
But I do agree, on most cards its auto all the way 🙂
I will always run a bit higher temperature ( within safe limits ) to reduce noise though.
https://linustechtips.com/topic/1598014-ok-fan-curve/#findComment-16634993
current PC:
PCs I used before:
https://linustechtips.com/topic/1598014-ok-fan-curve/#findComment-16635035
