Need help with removing motion blur on Final fantasy 7 rebirth
I'm trying to remove motion blur and edit depth of field. I was able to do it on my PC as the steps are straight forward using the link below, on top of adding dlss 4.
https://www.nexusmods.com/finalfantasy7remake/mods/74?tab=files
However, my issue is on my steam deck, I don't know where to put the engine.ini file. Now this is where it should go on windows "Documents\My Games\FINAL FANTASY VII REBIRTH\Saved\Config\WindowsNoEditor\", so what is the steamos/linux counterpart for this folder?
Edit: never mind, just found it. Imagine that, chatgpt helped.
