Fan hub problems
Go to solution Solved by Average Nerd,
14 minutes ago, AirNinja said:
I dont see a power pin on the fan hub
There should be a SATA power cable included with the case, according to the manual:
Hi
I built a new pc using an Antec Flux pro case and a b650 pro-a mobo, the case comes with 6 pre-installed non-rgb fans, 5 of which are connected to a fan hub. I have tried plugging the 2 pin coming out of the hub into the pump_fan header and a sys_fan header but haven't got the 5 fans to spin. I've looked at guides and other similar posts on reddit to no avail.
Could I please have some help.
Thank you in advance
https://linustechtips.com/topic/1597744-fan-hub-problems/
Do you have the fan hub plugged into  power? The two pins are only the pwm signals.
Failure is part of success. I may make mistakes, that's how we all learn.
Please quote or @ me if you want me to be notified. Mark replies as answers if they solved your problem.
Folding at Home
https://linustechtips.com/topic/1597744-fan-hub-problems/#findComment-16633108
case-240627_Antec_Flux Pro_Manual_compressed.pdf
Page: 32
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – Intel Core i7-10700K + Corsair Hydro Series H100x – G.SKILL TridentZ RGB 32GB (F4-3600C16Q-32GTZR) – ASUS ROG STRIX RTX 3080Ti OC LC – ASUS ROG STRIX Z490-G GAMING (Wi-Fi) – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB, Crucial MX500 2TB, Crucial MX300 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless –
ASUS ROG Claymore II Wireless – ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1597744-fan-hub-problems/#findComment-16633126
English is not my first language, so please excuse any confusion or misunderstandings on my end, also I like to edit my posts a lot.
F@H-Stats (expand for machine specs)
The Folding rigs:
Rig 1:
CPU: 2x Xeon E5 2690 V3
Rig 2:
CPU: Ryzen 5 5600
GPU: GTX 1080
Rig 3:
CPU: Core i7 4790K
GPU: GTX 1060 3GB
The Laptop (Lenovo Legion 5 15IAH7):
CPU: Core i5 12500H
RAM: 16GB (2x8GB) DDR5-4800
GPU: RTX 3050 Ti mobile
OS: Windows 11 Home
The Tablet:
Dell Latitude 7212 Rugged Extreme Tablet (Core i5 8350U)
OS: Windows 11 Pro
Hello!
https://linustechtips.com/topic/1597744-fan-hub-problems/#findComment-16633128
