Need a list of components for a server build for small business
Solved by Eigenvektor,
2 hours ago, Shubham kumar pandey said:I don't know how that works but as I know the software handles the mqtt part hosts a website for the coustomer to see the dashboard and all for each and every coustomer and we also have a application for the phones so it is like the Arduino iot cloud
Our software is similar in that it also hosts a website, communicates with mobile devices (MQTT/FCM/APNS/WNS), multiple other external services and has an underlying database.
It does not require anywhere near that amount of hardware.
I would recommend to run a load test with a small number of devices and do some extrapolation based on that, before overspending on hardware.
