On 1/22/2025 at 10:37 PM, Bdavis said:
Unifi all the way. Cloud gateway Max or dream machine pro.
Okay thanks! I was considering the Unifi dream "r2d2" but you think the gateway max would be better?
https://store.ui.com/us/en/category/cloud-gateways-wifi-integrated/products/udr
It depends on the speeds your trying to achieve. Gateway Max has 2.5gb wan and lan ports.
