Budget (including currency): 1500$
Country: United States
So I'm trying to decide on whether to upgrade my old rig or build a whole new computer and I have no idea what my computer would realistically sell for. I built my PC during the start of Covid in 2020 and used it for almost exclusively gaming, and I never did any crazy demanding games, mostly minecraft, valorant, and terraria. My current specs are as follows:
CPU - Ryzen 5 3600 - New: 94$
CPU Cooler - Vetroo v5 - New: 25$
RAM - G. Skill Ripjaws 2x8 3600 MHZ - New: 36$
GPU - Gigabyte GeForce GTX 1070 8Gb Windforce - New: 300$ (Not sure why its so much)
Motherboard - ASRock Phantom Gaming 4 B550 - New: 128$
Storage - Kingston NV2 1TB M.2 - New: 60$
Case - Phanteks Eclipse P360a - New: ~90$
PSU - I think EVGA 650 W 80+ Bronze rated - New: 90$
Total NEW: $823
I know it won't sell for probably 60% even of the original new price, so I was just curious what a good price would be for me to sell this at, OR if I should stick with AM4 and upgrade the current build (I would put in a new GPU, ram, and CPU) instead of upgrading to AM5 with a entire new build. Any help is appreciated thanks
If you don't play any super demanding games, a 5800X3D (still on AM4) would last you for many, many years. After the new 50 series and AMD GPUs release, you could get a current gen GPU, like a 4060 Ti for cheaper. According to Techpowerup, a 4060 Ti is equal to a 2080 Ti at 1080p, and just 8-10% slower than that at 4K.
First Computer: 3440x1440 @75Hz ROG STRIX 1080 Ti Core i5 8600K @ 1.415V @ 5.08 GHz Corsair Spec 02 EVGA CLC 280mm
Forget what it cost new during COVID. What you have may sell for $200-$300. All the hardware is what people upgrade from and not to.
The good news is, a 3D CPU, 32GB RAM and new GPU could make that quite a bit faster for much less $ than new platform. It sounds like you are not playing extremely new and high resolution games.
No signature
Appraisal from new price doesn't work for a high depreciation product like tech and cars.
PCPartPicker Part List
CPU: AMD Ryzen 7 5700X3D 3 GHz 8-Core Processor  ($249.00 @ Amazon)
CPU Cooler: ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  ($29.99 @ Amazon)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($42.97 @ Newegg Sellers)
Storage: Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($90.97 @ B&H)
Video Card: NVIDIA Founders Edition GeForce RTX 5080 16 GB Video Card  ($1000.00)
Power Supply: Enermax REVOLUTION D.F. 2 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Total: $1502.92
Generated by PCPartPicker 2025-01-20 22:33 EST-0500
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
