7 minutes ago, Walter101 said:
I just got my ryzen 5 9600x and it is reaching 90C with a 360mm EK AIO on 105w tdp and i have good thermal paste and removed all plastic peels. Should it be running this hot? also my motherboard is a gigabyte x670 aorus elite ax. Any fixes?
Is this during gaming or 100% load like cinebench?
High temperatures on a Ryzen 7000 and 9000 series of CPU's is completely normal.
They are actually made to run at 95C 24/7.
The CPU IS actually designed to reach 95c before limiting clocks or power.
What you are seeing is normal for a Ryzen 9600x.  It doesn't actually matter what cooler, it will go high in temp.
I will link 2 videos that explain this further.
Timed this GN video. skip to 24:16 at the end for further information.
Dont be alarmed by the fire in the thumbnails, just for clicks 🙂
The Ryzen 9000 series behaves the same as Ryzen 7000.
https://linustechtips.com/topic/1597408-9600x-running-very-hot/#findComment-16630483
4 minutes ago, Walter101 said:
This is while running cinebench, thanks for the response
Perfectly normal then. Absolutely nothing to worry about!  90c is actually fairly decent considering a cinebench run.
Watch the videos if you want.
But overall, absolutely nothing to worry about.  Just continue using the system as you normally would 🙂
https://linustechtips.com/topic/1597408-9600x-running-very-hot/#findComment-16630489
