Finished the build and we go to plug it in and it’s stuck turning on and off, we confirmed it wasn’t anything with the gpu by testing it with another computer and anything plugged into it is unresponsive. No power from usbs even if it’s plugged into the io. Tried resetting CMOS for 5 minutes and nothing. Motherboard Asus B560 plus, used from Amazon, i7-11700, rtx 3060 , 2 sticks of dual 8gb 3200 RAM .IMG_2651.thumb.jpeg.b4b716debfe81261494c3aa443d5da68.jpeg
try with 1 stick of ram (each slot)
try with different ram
is there anything on screen at all?
do you get into BIOS?
it kinda sounds like mobo is perhaps defective... can try to reset CMOS tho, otherwise replace the mobo.
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
We solved it, my cpu got damaged 😭. However we had a replacement that works just as well so it’s okay. Ty for the help
