I recently bought a used computer from 2023, the warranty of all the parts are still on, and they works perfectly at the first 5 days. And then suddenly without making any changes to the computer, the morning i start playing valorant it crashes and a text saying "Graphic drivers crashed". but i thought it was just a minor problem til i started the game again, the display just suddenly turns black screen while the pc still on.
And then i restarted the computer, and now it definitely wont show display, While my RGB is on and the Fans are spinning.
Is it that my GPU got permanently damaged or was it other parts?
Im running I5-13400F with RTX 3080 Inno3D, with 650W NZXT Semi modular.
8 hours ago, Neutraliz said:
Hi,
Oh wow a 3080 with only a 650W? That poor PSU is stressed af.
650W is low for a 3080. I'd upgrade that to 850W.
That's my first suspect right away.
I have a similar issue. I have an amd 6600 and a 650w psu . Any ideas I can do to fix it ? Hdmi does not show any signal as well
